Bäm! @einsiedlerkrebs starts publishing data using a multihop FSK setup (RFM69 -> RFM95 -> LinkIt -> BERadio -> MQTT).
About the setup
- The Generic firmware is running in different modes on three AVR MCUs (node, transceiver, gateway).
- A HopeRF RFM95 LoRa RF transceiver module is wired to the ATmega32U4 of the LinkIt Smart 7688 Duo.
- The BERadio gateway is running on the LinkIt Smart 7688 Duo and does the convergence to the MQTT bus.
More details
- @einsiedlerkrebs writes about his efforts at 7688 Duo as RFM95 to Wifi-BERadio gateway and Hands on LinkIt Smart 7688 Duo without Arduino IDE, thanks a bunch!
Data
- Grafana
- https://swarm.hiveeyes.org/api/hiveeyes/fe344422-05bf-40f2-a299-fbf4df5d7e2b/vay55/2/data.txt
P.S.: Finally using this setup in the field starting April 2017 is a big step forward after the early prototyping phases in May 2016 (see LoRa ahead!) and July 2016 (see Next-generation sensor- and telemetry-node firmware).
Cheers, @einsiedlerkrebs!
