Over at Unlocking LoRaWAN / TTN on the LoPy4 within Terkin, @Thias is starting with the LoPy4. We are handling some issues about this guy here.
LoPy4 Log ohne angeschlossene Sensoren mit Sandbox Firmware nach Refactoring vom 31.10.2019 [1] und Pycom Firmware (pybytes per pybytes_config.json deaktiviert)
vorab:
rm -rf dist-packages
make setup
make install
bringt mich zu:
Pycom MicroPython 1.20.1.r1 [v1.11-3138a13] on 2019-10-08; LoPy4 with ESP32
Pybytes Version: 1.1.3
>>> import machine ; machine.reset()
ets Jun 8 2016 00:22:57
rst:0x7 (TG0WDT_SYS_RESET),boot:0x12 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
mode:DIO, clock div:1
load:0x3fff8020,len:8
load:0x3fff8028,len:2136
load:0x4009fa00,len:19880
entry 0x400a05d0
[boot.py] INFO: Python module search path is: ['', '/flash', '/flash/lib']
[boot.py] INFO: Starting "mboot" bootloader
[mboot] INFO: Python module search path is: ['/flash/lib-mpy-1.11-pycom', '', '/flash', '/flash/lib', '/flash/dist-packages', '/flash/terkin']
Pybytes configuration read from /flash/pybytes_config.json
Not starting Pybytes as auto-start is disabled
[main.py] INFO: Loading Terkin Datalogger
14.8634 [terkin.datalogger ] INFO : Starting Terkin datalogger
14.8813 [terkin.configuration ] INFO : Starting TerkinConfiguration on path "/flash"
14.8995 [terkin.configuration ] INFO : Ensuring existence of backup directory at "/flash/backup"
15.0199 [terkin.configuration ] INFO : Reading configuration file /flash/settings-user.json
15.0426 [terkin.configuration ] INFO : User settings: {}
15.5960 [terkin.device ] WARNING: Could not determine reset cause
15.6105 [terkin.watchdog ] INFO : Skipping watchdog timer (WDT)
16.1655 [terkin.device ] INFO : Start curating the garbage collector
16.4703 [terkin.device ] INFO : Curating the garbage collector finished. Free memory: 2392384
16.4969 [terkin.device ] INFO : Turning off Bluetooth
17.1289 [terkin.watchdog ] INFO : Resuming watchdog
17.1499 [terkin.datalogger ] INFO : Starting Terkin MicroPython Datalogger 0.6.0
17.1769 [terkin.configuration ] INFO : Configuration settings:
17.2163 [terkin.configuration ] INFO : Section "telemetry": {"targets": [{"enabled": true, "topology": "mqttkit", "endpoint": "mqtt://swarm.hiveeyes.org", "address": {"network": "testdrive", "gateway": "thias", "node": "lopy4-mqtt-json", "realm": "hiveeyes"}}, {"enabled": false, "topology": "mqttkit", "endpoint": "https://daq.example.org/api", "address": {"network": "testdrive", "gateway": "area-42", "node": "node-01-http-json", "realm": "workbench"}}, {"enabled": false, "data": {"key": "## redacted ##"}, "endpoint": "https://test.free.beeceptor.com/api/sensors"}, {"encode": "base64", "format": "lpp", "address": {"network": "testdrive", "gateway": "area-42", "node": "node-01-mqtt-lpp", "realm": "workbench"}, "enabled": false, "endpoint": "mqtt://daq.example.org"}]}
17.2992 [terkin.configuration ] INFO : Section "interfaces": {"uart0": {"terminal": true}}
17.3310 [terkin.configuration ] INFO : Section "networking": {"wifi": {"phy": {"antenna_external": false, "antenna_pin": "P12"}, "stations": [{"ssid": "WerNet", "password": "## redacted ##"}]}, "lora": {"otaa": {"application_eui": "## redacted ##", "datarate": 0, "frequency": 868100000, "region": "LoRa.EU868", "application_key": "## redacted ##", "device_eui": "007A2C890789A9B3"}, "antenna_attached": true}}
17.3867 [terkin.configuration ] INFO : Section "main": {"rgb_led": {"terkin": true, "heartbeat": false}, "watchdog": {"enabled": false, "timeout": 60000}, "interval": {"maintenance": 15.0, "field": 60.0}, "fastboot": true, "backup": {"file_count": 7}, "deepsleep": false, "logging": {"enabled": true, "configuration": true}}
17.4658 [terkin.configuration ] INFO : Section "sensors": {"system": [{"type": "system.memfree"}, {"type": "system.temperature"}, {"type": "system.uptime"}, {"type": "system.wifi"}, {"enabled": false, "type": "system.touch-buttons"}, {"pin": "P16", "resistor_r2": 1000, "resistor_r1": 1000, "enabled": true, "type": "system.battery-voltage"}], "environment": [{"pin_dout": "P22", "scale": 4.424242, "offset": -73000, "enabled": false, "name": "scale", "description": "Waage 1", "id": "scale-1", "number": 0, "pin_pdsck": "P21", "type": "HX711"}, {"enabled": false, "bus": "onewire:0", "name": "temperature", "description": "Wabengasse 1", "id": "ds18b20-1", "type": "DS18B20", "devices": [{"id": "ds18b20-r1c1", "enabled": false, "address": "1111111111111111", "description": "Reihe 1, Spalte 1"}, {"id": "ds18b20-r1c2", "enabled": false, "address": "2222222222222222", "description": "Reihe 1, Spalte 2"}]}, {"id": "bme280-1", "description": "Temperatur und Feuchte auĂen", "type": "BME280", "address": 119, "enabled": false, "bus": "i2c:0"}], "busses": [{"id": "bus-i2c-0", "family": "i2c", "number": 0, "pin_sda": "P9", "enabled": false, "pin_scl": "P10"}, {"id": "bus-i2c-1", "family": "i2c", "number": 1, "pin_sda": "P22", "enabled": false, "pin_scl": "P21"}, {"enabled": true, "family": "onewire", "pin_data": "P11", "id": "bus-onewire-0", "number": 0}], "prettify_log": true}
17.6095 [terkin.configuration ] INFO : Section "services": {"api": {"modeserver": {"enabled": true}, "http": {"enabled": true}}}
System memory info (in bytes)
MPTask stack water mark: 5016
ServersTask stack water mark: 3628
LoRaTask stack water mark: 3516
SigfoxTask stack water mark: 2752
TimerTask stack water mark: 2136
IdleTask stack water mark: 612
System free heap: 383064
17.7417 [terkin.device ] INFO :
CPU freq 160.0 MHz
Device id 807d3a936500
Python : 3.4.0
lorawan : 1.0.2
machine : LoPy4 with ESP32
nodename: LoPy4
pybytes : 1.1.3
release : 1.20.1.r1
sigfox : 1.0.1
sysname : LoPy4
version : v1.11-3138a13 on 2019-10-08
17.7816 [terkin.device ] INFO : Starting networking
17.8194 [terkin.network.wifi ] INFO : Starting stopwatch
17.9271 [terkin.network.wifi ] INFO : Started stopwatch successfully
18.0288 [terkin.network.wifi ] INFO : WiFi STA: Networking address (MAC): {'ap_mac': '00:00:00:00:00:00', 'sta_mac': '80:7d:3a:93:65:00'}
18.0440 [terkin.network.wifi ] INFO : WiFi STA: Networking address (IP): ('0.0.0.0', '0.0.0.0', '0.0.0.0', '0.0.0.0')
18.0591 [terkin.network.wifi ] INFO : WiFi: Starting interface
18.0736 [terkin.network.wifi ] INFO : WiFi: Using internal antenna
18.1091 [terkin.device ] INFO : Start curating the garbage collector
18.4141 [terkin.device ] INFO : Curating the garbage collector finished. Free memory: 2392064
18.5238 [terkin.network.core ] INFO : Waiting for the network stack to come up within 5 seconds
18.5885 [terkin.network.core ] INFO : Network stack ready
18.6216 [terkin.network.core ] INFO : Starting mode server on 0.0.0.0:666
24.5066 [terkin.api.http ] INFO : Setting up HTTP API
24.7909 [terkin.api.http ] INFO : Starting HTTP server
24.8190 [terkin.network.core ] ERROR : Starting HTTP server failed
File "/flash/lib/terkin/network/core.py", line 126, in start_services
File "/flash/lib/terkin/network/core.py", line 144, in start_httpserver
File "/flash/lib/terkin/api/http.py", line 72, in start
File "/flash/dist-packages/microWebSrv.py", line 219, in Start
OSError: Network card not available
25.6287 [terkin.network.wifi ] INFO : WiFi STA: Connecting to configured networks: ['WerNet']. Attempt: #1
25.6544 [terkin.network.wifi ] INFO : WiFi STA: Preparing connection to network "WerNet"
25.6747 [terkin.network.wifi ] INFO : WiFi STA: Getting auth mode
25.7561 [terkin.network.wifi ] INFO : WiFi STA: Auth mode from NVRAM with key=wa.9d66b1d414d4, value=3
25.7803 [terkin.network.wifi ] INFO : WiFi STA: Auth mode is "3"
25.8077 [terkin.network.wifi ] INFO : WiFi STA: Starting connection to "WerNet" with timeout of 15.0 seconds
25.9372 [terkin.network.wifi ] INFO : WiFi STA: Waiting for network to come up within 14.997 seconds
Unhandled exception in thread started by <bound_method>
File "/flash/lib/terkin/network/ip.py", line 31, in start_real
28.2280 [terkin.network.lora ] INFO : [LoRA] Not joined yet...
28.9669 [terkin.network.wifi ] INFO : WiFi STA: Waiting for network to come up within 11.967 seconds
30.8810 [terkin.network.lora ] INFO : [LoRA] Not joined yet...
31.9800 [terkin.network.wifi ] INFO : WiFi STA: Waiting for network to come up within 8.953 seconds
33.5002 [terkin.network.lora ] INFO : [LoRA] Not joined yet...
34.9862 [terkin.network.wifi ] INFO : WiFi STA: Waiting for network to come up within 5.947 seconds
36.1194 [terkin.network.lora ] INFO : [LoRA] Not joined yet...
37.9933 [terkin.network.wifi ] INFO : WiFi STA: Waiting for network to come up within 2.94 seconds
38.7396 [terkin.network.lora ] INFO : [LoRA] Not joined yet...
40.9576 [terkin.network.wifi ] ERROR : Invoking "is_connected" failed
File "/flash/lib/terkin/network/wifi.py", line 192, in is_connected
TimeoutError: Connection to AP Timeout!
41.0547 [terkin.network.wifi ] ERROR : WiFi STA: Connecting to "WerNet" failed
File "/flash/lib/terkin/network/wifi.py", line 240, in connect_stations
File "/flash/lib/terkin/network/wifi.py", line 310, in connect_station
WiFiException: WiFi STA: Unable to connect to "WerNet"
41.0986 [terkin.network.wifi ] INFO : WiFi STA: Forgetting NVRAM data for network "WerNet"
41.2004 [terkin.network.wifi ] ERROR : WiFi STA: Connecting to any network candidate failed. Please check your WiFi configuration for one of the 1 station candidates.
41.2258 [terkin.network.wifi ] WARNING: Todo: We might want to buffer telemetry data to flash memory to be scheduled for transmission later.
41.2660 [terkin.network.wifi ] ERROR : WiFi STA: Connecting to configured networks "['WerNet']" failed
File "/flash/lib/terkin/network/wifi.py", line 176, in stay_connected
File "/flash/lib/terkin/network/wifi.py", line 257, in connect_stations
WiFiException: WiFi STA: Connecting to any network candidate failed
41.3621 [terkin.network.wifi ] INFO : WiFi STA: Retrying in 1.962988 seconds
41.4828 [terkin.network.lora ] INFO : [LoRA] Not joined yet...
41.5048 [terkin.network.lora ] INFO : [LoRA] joined...
43.3453 [terkin.network.wifi ] INFO : WiFi STA: Connecting to configured networks: ['WerNet']. Attempt: #2
43.3732 [terkin.network.wifi ] INFO : WiFi STA: Preparing connection to network "WerNet"
43.3948 [terkin.network.wifi ] INFO : WiFi STA: Getting auth mode
43.4763 [terkin.network.wifi ] INFO : WiFi STA: Unknown auth mode for network "WerNet", invoking WiFi scan
43.4991 [terkin.network.wifi ] INFO : WiFi STA: Scanning for networks
44.0264 [terkin.network.lora ] INFO : [LoRa] socket created
45.6930 [terkin.network.wifi ] INFO : WiFi STA: Networks available: ['DIRECT-6C-HP OfficeJet Pro 6970', 'KDG-60B0A', 'TC-9BB6D', 'KabelBox-A0C8', 'WerNet', 'SprinterBoxGast', 'o2-WLAN35', 'NETGEAR85', 'SprinterBox', 'WLAN-209719', 'Kuschelnetz', 'FRITZ!Box 7430 SW', 'Ourhome_24', 'Mesh23', 'Siemensstr Home 2,4', 'DIRECT-277310A9', 'Minionelch', 'ShadowyPlanet', 'WLAN-728781', 'Telekom_FON', 'KDG-029D0', 'FRITZ!Box 7490', 'DIRECT-hqC48x Series', 'freifunk-potsdam.de', 'Powers-Box']
45.7501 [terkin.network.wifi ] INFO : WiFi STA: Storing auth mode into NVRAM with key=wa.9d66b1d414d4, value=3
45.7764 [terkin.network.wifi ] INFO : WiFi STA: Auth mode is "3"
45.8047 [terkin.network.wifi ] INFO : WiFi STA: Starting connection to "WerNet" with timeout of 15.0 seconds
45.9322 [terkin.network.wifi ] INFO : WiFi STA: Waiting for network to come up within 14.998 seconds
46.2573 [terkin.network.wifi ] INFO : WiFi STA: Connected to "WerNet" with IP address "192.168.188.40"
46.3493 [terkin.network.wifi ] INFO : WiFi STA: Networking address (MAC): {'ap_mac': '00:00:00:00:00:00', 'sta_mac': '80:7d:3a:93:65:00'}
46.3736 [terkin.network.wifi ] INFO : WiFi STA: Networking address (IP): ('192.168.188.40', '255.255.255.0', '192.168.188.1', '192.168.188.189')
48.2523 [terkin.device ] INFO : Starting telemetry
48.2938 [terkin.telemetry ] INFO : Telemetry channel topology: MqttKitTopology
48.3358 [terkin.telemetry ] INFO : Telemetry channel URI: mqtt://swarm.hiveeyes.org/hiveeyes/testdrive/thias/lopy4-mqtt-json
48.3587 [terkin.telemetry ] INFO : Starting Terkin TelemetryClient
48.4193 [terkin.sensor.core ] INFO : Starting all busses [{'enabled': False, 'family': 'i2c', 'pin_scl': 'P10', 'pin_sda': 'P9', 'id': 'bus-i2c-0', 'number': 0}, {'enabled': False, 'family': 'i2c', 'pin_scl': 'P21', 'pin_sda': 'P22', 'id': 'bus-i2c-1', 'number': 1}, {'pin_data': 'P11', 'id': 'bus-onewire-0', 'number': 0, 'family': 'onewire', 'enabled': True}]
48.4695 [terkin.sensor.core ] INFO : Bus with id "bus-i2c-0" and family "i2c" is disabled, skipping registration
48.4978 [terkin.sensor.core ] INFO : Bus with id "bus-i2c-1" and family "i2c" is disabled, skipping registration
48.6521 [terkin.sensor.core ] ERROR : 1-Wire hardware driver failed
File "/flash/lib/terkin/sensor/core.py", line 277, in start
ImportError: no module named 'onewire.OneWire'
48.6878 [terkin.sensor.core ] INFO : Registering bus "onewire:0"
48.7096 [terkin.datalogger ] INFO : Registering sensors
48.7767 [terkin.datalogger ] INFO : Setting up sensor with with id=system.memfree and type=system.memfree on bus=None with address=None described as "None"
48.8343 [terkin.datalogger ] INFO : Setting up sensor with with id=system.temperature and type=system.temperature on bus=None with address=None described as "None"
48.8774 [terkin.datalogger ] INFO : Setting up sensor with with id=system.uptime and type=system.uptime on bus=None with address=None described as "None"
48.9199 [terkin.datalogger ] INFO : Setting up sensor with with id=system.wifi and type=system.wifi on bus=None with address=None described as "None"
48.9632 [terkin.datalogger ] INFO : Setting up sensor with with id=system.touch-buttons and type=system.touch-buttons on bus=None with address=None described as "None"
48.9953 [terkin.datalogger ] INFO : Sensor with id=system.touch-buttons is disabled, skipping registration
49.0359 [terkin.datalogger ] INFO : Setting up sensor with with id=system.battery-voltage and type=system.battery-voltage on bus=None with address=None described as "None"
SystemVoltage settings: {'resistor_r2': 1000, 'resistor_r1': 1000, 'enabled': True, 'pin': 'P16', 'type': 'system.battery-voltage'}
49.1348 [terkin.datalogger ] INFO : Setting up sensor with with id=scale-1 and type=hx711 on bus=None with address=None described as "Waage 1"
49.1623 [terkin.datalogger ] INFO : Sensor with id=scale-1 is disabled, skipping registration
49.1849 [terkin.sensor.core ] INFO : Trying to find bus by name "onewire:0"
49.2059 [terkin.sensor.core ] INFO : Found bus by name "onewire:0": <OneWireBus object at 3f97f480>
49.2461 [terkin.datalogger ] INFO : Setting up sensor with with id=ds18b20-1 and type=ds18b20 on bus=onewire:0 with address=None described as "Wabengasse 1"
49.2754 [terkin.datalogger ] INFO : Sensor with id=ds18b20-1 is disabled, skipping registration
49.2981 [terkin.sensor.core ] INFO : Trying to find bus by name "i2c:0"
49.3192 [terkin.sensor.core ] INFO : Found bus by name "i2c:0": None
File "main.py", line 43, in <module>
File "main.py", line 38, in main
File "/flash/lib/terkin/datalogger.py", line 176, in start
File "/flash/lib/terkin/datalogger.py", line 329, in register_sensors
AttributeError: 'NoneType' object has no attribute 'name'
[1] Large refactoring ¡ hiveeyes/hiveeyes-micropython-firmware@2a835be ¡ GitHub
Thanks for writing in and also thanks for
We are already doing some network-related investigations over at Troubleshooting the recent Pycom Firmware Release 1.20.1.r1.
While we see pybytes
has been disabled successfully through pybytes_config.json
we still feel that the error message
might be related to that.
So, we are humbly asking to use a firmware build without pybytes
, which we just uploaded to https://packages.hiveeyes.org/hiveeyes/foss/pycom/LoPy4-1.20.1.r1-vanilla-0.1.0.tar.gz.
This is a complete firmware image which can be flashed to the device through the Pycom Firmware Updater, as outlined on Installing the recent Pycom Firmware 1.20.1.r1 requires erasing the flash memory completely - #6 by Andreas. Please make sure to use the erase_all
command first.
On Linux, the appropriate procedure might be
wget https://packages.hiveeyes.org/hiveeyes/foss/pycom/LoPy4-1.20.1.r1-vanilla-0.1.0.tar.gz
pycom-fwtool-cli --verbose --port /dev/ttyS0 erase_all
pycom-fwtool-cli --verbose --port /dev/ttyS0 flash --tar LoPy4-1.20.1.r1-vanilla-0.1.0.tar.gz
We will be happy to hear about the outcome for you.
Line 277 in the current sensor/core.py
looks like from onewire import OneWire
for us. Can you confirm this is also true for you and matches the same thing on the device itself?
This indicates you might be running with an outdated settings.py
. We just refactored this through Large refactoring ¡ hiveeyes/terkin-datalogger@2a835be ¡ GitHub and humbly ask you to adapt the sensors.system
section like outlined within https://github.com/hiveeyes/hiveeyes-micropython-firmware/blob/master/settings.example.py#L205-L229.
We just added another wave of refactoring through Improve multi-platform support ¡ hiveeyes/hiveeyes-micropython-firmware@21314d9 ¡ GitHub, so we also humbly ask you to pull the most recent thing from master.
with
Board erased successfully in 20.4 seconds
and
Writing lopy4.bin at 0x00110000... (100 %)
Hash of data verified.
Wrote 2027520 bytes (1051577 compressed) at 0x00010000 in 19.7 seconds (822.3 kbit/s)...
and
make install
I confirm the ânetwork card not available errorâ is gone. Thanks for preparing the pybytesless firmware!
WiFi always needs two attempts to establish a connection
13.8409 [terkin.device ] INFO : Starting networking
13.8697 [terkin.network.wifi ] INFO : Starting stopwatch
13.9666 [terkin.network.wifi ] INFO : Started stopwatch successfully
14.0106 [terkin.network.wifi ] INFO : WiFi STA: Networking address (MAC): {'ap_mac': '80:7d:3a:93:65:01', 'sta_mac': '80:7d:3a:93:65:00'}
14.0228 [terkin.network.wifi ] INFO : WiFi STA: Networking address (IP): ('0.0.0.0', '0.0.0.0', '0.0.0.0', '0.0.0.0')
14.0351 [terkin.network.wifi ] INFO : WiFi: Starting interface
14.0464 [terkin.network.wifi ] INFO : WiFi: Using internal antenna
14.0742 [terkin.device ] INFO : Start curating the garbage collector
14.3673 [terkin.device ] INFO : Curating the garbage collector finished. Free memory: 2394304
14.4658 [terkin.network.core ] INFO : Waiting for the network stack to come up within 5 seconds
14.5229 [terkin.network.core ] INFO : Network stack ready
14.5472 [terkin.network.core ] INFO : Starting mode server on 0.0.0.0:666
19.5743 [terkin.api.http ] INFO : Setting up HTTP API
19.7911 [terkin.api.http ] INFO : Starting HTTP server
20.4807 [terkin.network.wifi ] INFO : WiFi STA: Connecting to configured networks: ['WerNet']. Attempt: #1
20.5030 [terkin.network.wifi ] INFO : WiFi STA: Preparing connection to network "WerNet"
20.5198 [terkin.network.wifi ] INFO : WiFi STA: Getting auth mode
20.5913 [terkin.network.wifi ] INFO : WiFi STA: Auth mode from NVRAM with key=wa.9d66b1d414d4, value=3
20.6116 [terkin.network.wifi ] INFO : WiFi STA: Auth mode is "3"
20.6345 [terkin.network.wifi ] INFO : WiFi STA: Starting connection to "WerNet" with timeout of 30.0 seconds
20.7520 [terkin.network.wifi ] INFO : WiFi STA: Waiting for network to come up within 29.997 seconds
23.0801 [terkin.network.lora ] INFO : [LoRA] Not joined yet...
24.0355 [terkin.network.wifi ] INFO : WiFi STA: Waiting for network to come up within 26.713 seconds
25.6984 [terkin.network.lora ] INFO : [LoRA] Not joined yet...
25.7161 [terkin.network.lora ] INFO : [LoRA] joined...
27.0099 [terkin.network.wifi ] INFO : WiFi STA: Waiting for network to come up within 23.739 seconds
28.2332 [terkin.network.lora ] INFO : [LoRa] socket created
29.9835 [terkin.network.wifi ] INFO : WiFi STA: Waiting for network to come up within 20.766 seconds
47.7789 [terkin.network.wifi ] INFO : WiFi STA: Waiting for network to come up within 2.969999 seconds
50.7027 [terkin.network.wifi ] ERROR : Invoking "is_connected" failed
File "/flash/lib/terkin/network/wifi.py", line 193, in is_connected
50.7909 [terkin.network.wifi ] ERROR : WiFi STA: Connecting to "WerNet" failed
File "/flash/lib/terkin/network/wifi.py", line 241, in connect_stations
File "/flash/lib/terkin/network/wifi.py", line 311, in connect_station
50.8319 [terkin.network.wifi ] INFO : WiFi STA: Forgetting NVRAM data for network "WerNet"
50.9227 [terkin.network.wifi ] ERROR : WiFi STA: Connecting to any network candidate failed. Please check your WiFi configuration for one of the 1 station candidates.
50.9454 [terkin.network.wifi ] WARNING: Todo: We might want to buffer telemetry data to flash memory to be scheduled for transmission later.
50.9794 [terkin.network.wifi ] ERROR : WiFi STA: Connecting to configured networks "['WerNet']" failed
File "/flash/lib/terkin/network/wifi.py", line 177, in stay_connected
File "/flash/lib/terkin/network/wifi.py", line 258, in connect_stations
51.0679 [terkin.network.wifi ] INFO : WiFi STA: Retrying in 1.643164 seconds
52.7294 [terkin.network.wifi ] INFO : WiFi STA: Connecting to configured networks: ['WerNet']. Attempt: #2
52.7544 [terkin.network.wifi ] INFO : WiFi STA: Preparing connection to network "WerNet"
52.7735 [terkin.network.wifi ] INFO : WiFi STA: Getting auth mode
52.8464 [terkin.network.wifi ] INFO : WiFi STA: Unknown auth mode for network "WerNet", invoking WiFi scan
52.8667 [terkin.network.wifi ] INFO : WiFi STA: Scanning for networks
55.0350 [terkin.network.wifi ] INFO : WiFi STA: Networks available: ['NETGEAR85', 'WLAN-209719', 'Telekom_FON', 'Minionelch', 'FRITZ!Box 7560 DF', 'DIRECT-hqC48x Series', 'ShadowyPlanet', 'Mesh23', 'WerNet', 'freifunk-potsdam.de', 'devolo-f4068d8dc4d9', 'Potsdambabel', 'WLAN-728781', 'FRITZ!Box 7490 HKS', 'ARRIS-41A2', 'o2-WLAN35', 'Kuschelnetz', 'DIRECT-6C-HP OfficeJet Pro 6970', 'WLAN-EVS8XJ', 'TC-9BB6D', 'KDG-029D0', 'KabelBox-A0C8', 'o2-WLAN09']
55.0860 [terkin.network.wifi ] INFO : WiFi STA: Storing auth mode into NVRAM with key=wa.9d66b1d414d4, value=3
55.1090 [terkin.network.wifi ] INFO : WiFi STA: Auth mode is "3"
55.1337 [terkin.network.wifi ] INFO : WiFi STA: Starting connection to "WerNet" with timeout of 30.0 seconds
55.2497 [terkin.network.wifi ] INFO : WiFi STA: Waiting for network to come up within 29.998 seconds
55.5621 [terkin.network.wifi ] INFO : WiFi STA: Connected to "WerNet" with IP address "192.168.188.40"
55.6405 [terkin.network.wifi ] INFO : WiFi STA: Networking address (MAC): {'ap_mac': '80:7d:3a:93:65:01', 'sta_mac': '80:7d:3a:93:65:00'}
55.6617 [terkin.network.wifi ] INFO : WiFi STA: Networking address (IP): ('192.168.188.40', '255.255.255.0', '192.168.188.1', '192.168.188.189') 47.7789 [terkin.network.wifi ] INFO : WiFi STA: Waiting for network to come up within 2.969999 seconds
hereafter no more logs are being produced
Just remembered that we also observed similar things like you outlined above at Stabilität und längere Testzeiträume des Terkin-Datenloggers - #64 by Andreas.
This also sounds familiar, see
Which means success or does the software just freeze afterwards?
I used to see the system variables to be printed and sent to swarm.hiveeyes.org in a loop before. Looks like a freeze
Seeing these weird errors again on your device, would you mind trying again with the webserver disabled?
'http': {
'enabled': False,
did this and make sketch-and-run
but log still stops after:
WiFi STA: Networking address (IP): ...
and resetting the board leads to Core 1 panic
Guru Meditation Error: Core 1 panic'ed (IllegalInstruction). Exception was unhandled.
Memory dump at 0x40200754: bad00bad bad00bad bad00bad
PS: Iâve never seen this panic before using the pybytes-less pycom firmware. Can this be related?
I think it has something to do with the new 1.20.1 firmware. I saw this with pybytes activate also, see Troubleshooting the recent Pycom Firmware Release 1.20.1.r1 - #2 by clemens > section Hiveeyes-Software
Sorry to hear that this also hits you on a LoPy4. You might alternatively check out https://packages.hiveeyes.org/hiveeyes/foss/pycom/LoPy4-1.20.1.r1-robert.tar.gz, thatâs all we can offer right now. This firmware image was built and provided by robert-hh.
If this error will not go away, you might well consider going back to the official pybytes firmwareâŚ
Sorry again, we are also just doing trial-and-error here on a regular basis. However, there are things indicating there might be something fishy under the hood.
- millis() crashes if used in irq handler called too early ¡ Issue #2699 ¡ espressif/arduino-esp32 ¡ GitHub
- Cant Access EEPROM over WIFI Handler - ESP32 Forum
Other users are also reporting these core panics on the Pycom user forum.
Please also enjoy
So, things like Soft errors caused by single-event upsets (SEUs) aka. ECC RAM absolutely matters might not be unrelated at all. Maybe some device models or revisions are more fragile than others.
Saying this kiddingly, I strongly believe this issue is more likely related to Random memory corruption faults on ESP32-WROVER rev.1 and rev.2 when running in dual-core mode.
Coming back from there, we built firmware images for the FiPy and the LoPy4 using
#define CONFIG_FREERTOS_UNICORE 1
I canât tell for sure whether this makes any difference at all as the FiPy on my workbench has been running pretty stable even before without that setting.
- https://packages.hiveeyes.org/hiveeyes/foss/pycom/LoPy4-1.20.1.r1-vanilla-unicore-0.1.0.tar.gz
- https://packages.hiveeyes.org/hiveeyes/foss/pycom/FiPy-1.20.1.r1-vanilla-unicore-0.1.0.tar.gz
Please also pull from our latest master as this will bring you Improve WiFi robustness on first connection attempt ¡ hiveeyes/terkin-datalogger@d3ae518 ¡ GitHub.
The AttributeError comes up, when bus-onewire-0
in settings.py is disabled
"number": 0,
"enabled": False,
"pin_data": "P11",
Thanks for letting us know. Are you sure you are running the latest version from master or did you make some modifications locally? At line 329, we are seeing an empty line there.
However, we just added [1] and [2] to mitigate all conditions when accessing a sensor object connected to a bus object which has been disabled through the configuration settings.
Again I saw these core panics also with the unicore
firmware. It starts happening after about 10 times flashing the device after PWRON
. After dis/reconnecting the device from/to power the error is gone, likely until the next 10 flash procedures.
