Pycom Firmware Release 1.20.2
Released 16 minutes ago.
Release Notes
Details
See Release Firmware release candidate v1.20.2.rc2 · pycom/pycom-micropython-sigfox · GitHub.
A post was split to a new topic: Squirrel firmware for Pycom/ESP32
Firmware release 1.20.2.rc7
… ist zwar noch nicht getagged, aber mindestens in Vorbereitung. Auf jeden Fall kam vorhin einiges bei Commits · pycom/pycom-micropython-sigfox · GitHub rein.
Firmware release 1.20.2.r4
Date: 12 Jan 2021
Die Pycom Firmware version 1.20.2 hat den “release candidate” Status im September 2020 mit Release Firmware Release v1.20.2.r1 · pycom/pycom-micropython-sigfox · GitHub verlassen.
Die aktuellste Variante ist die 1.20.2.r4 per Release Firmware Release v1.20.2.r4 · pycom/pycom-micropython-sigfox · GitHub vom 12. Jänner 2021.
Hier die entsprechenden Ankündigungen seit 1.20.2.r1:
Firmware release 1.20.2.r1
  • Pybytes v1.6.0
    • Sampling feature
    • Machine learning model deployment feature
Firmware release 1.20.2.r2
  • LTE: Check for SIM card before attaching
  • LTE: Add timeout parameter to lte_send_at_cmd
  • LTE: Improve exception texts
  • LTE: Callback LTE_EVENT_BREAK
  • LTE: Reduce AT+CEREG from 2 to 1
  • BLE: Fix a problem when machine.sleep(resume_wifi_ble=True)
  • BLE: Resume the BT Connection from the original list if connection was not…
  • BLE: Fix memory leak happens after Bluetooth disconnect
  • BLE: Fix address type handling
  • Pybytes version 1.6.1 - OTA bug fix
  • Pygate: Add pygate_reset() to power cycle the module
  • Pygate: reset the JIT queue margins
  • make: Add option MICROPY_FLOAT_IMPL PR 470
  • make: Pybytes and Pygate firmwares built from same source tree
Release Firmware Release v1.20.2.r2 · pycom/pycom-micropython-sigfox · GitHub
Firmware release 1.20.2.r3
  • Added micropython constant for manual antenna selection
  • LTE: fix core dump during machine.deepsleep()
  • Build: cleanup sigfox flags
  • LORA: buildflag and disable cleanly with pyeth
  • LTE: refactor lteppp_get_modem_conn_state()
  • LTE: detect modem in ffh/recovery mode
  • Make pycom.rgbled() return the current color value
  • User C modules: Enable in Makefile and application.mk
Release Firmware Release v1.20.2.r3 · pycom/pycom-micropython-sigfox · GitHub
  • RTC: utime/rtc/ntp fix (#206)
  • modcoap: fix memory issue
  • BLE: Add API create_128bit_le_uuid_from_string()
  • BLE: Fix an issue that Bluetooth init() failed after deinit()
Firmware release 1.20.2.r5
Date: 28 Oct 2021
  • Pybytes: version 1.7.0 with support for setting up a Pygate directly from Pybytes
  • Littlefs: wear-levelling and bugfixes (thanks robert-hh)
  • LoRa: bugfixes
  • Coap: bugfixes
  • Uart: bugfixes
  • Thread: bugfixes
  • WPA2 Enterprise: bugfixes
Release Firmware Release v1.20.2.r5 · pycom/pycom-micropython-sigfox · GitHub
Firmware release 1.20.2.r6
Date: 29 Oct 2021
  • pybytes version 1.7.1 - fix initialization
Release Firmware Release v1.20.2.r6 · pycom/pycom-micropython-sigfox · GitHub
