MicroPython tooling
REPL and file transfer tools and more
ampy
rshell
mpy-repl-tool
Documentation: https://mpy-repl-tool.readthedocs.io/
uPyLoader
There are binaries for Linux, macOS and Windows on its release page at Releases · BetaRavener/uPyLoader · GitHub.
https://github.com/BetaRavener/uPyLoader
Moar
mpy-cross and around
pydfu
Mount filesystem from MicroPython device on workstation
Continuing the discussion from DAQ-SIG recap 20190717:
Connecting some dots between MicroPython tooling and the
It looks like the mpy-REPL-Tool is able to synthesize a device mount of the filesystem on the device through fusepy – even on Windows using the Dokan FUSE Wrapper.
Mount Action
FUSE is a feature of the GNU/Linux kernel that allows to implement file system in user space programs. There are compatible libraries for MacOS and even for Windows.
fuse_drive.py implements a class for fusepy. It gets a connection which it’s using to execute commands on the target.
See also Getting mount to run on Windows, it currently requires a hack to get it working there.
Technical — mpy-REPL-Tool 0.2 documentation
The MicroTerkin Sandbox
Die MicroTerkin-Sandbox ist eine optimale commandline-basierte Entwicklungsumgebung für den Terkin-Datenlogger für MicroPython.
Paul Sokolovsky also made GitHub - pfalcon/awesome-micropython: Curated list of awesome MicroPython resources.
A post was split to a new topic: Monitoring and recording the serial interface output of a microcontroller attached to an UART interface
Jan Wieck just announced Micropython Build Environment for ESP32 in a Docker Container - MicroPython Forum.
