Guru Meditation Error: Core 0 panic'ed (Cache disabled but cached memory region accessed)
Guru Meditation Error: Core 0 panic'ed (IllegalInstruction). Exception was unhandled.
Memory dump at 0x40201de4: bad00bad bad00bad bad00bad
Sorry to hear about that. Then, your code will probably hit a different edge case with BLE. Thanks again for trying our firmware.
Bummer! Further information can be found at [1,2], but I fear that will not help us along.
Personally, I am not able to reproduce the core panic you are observing as I donโt have any BLE devices around advertising theirselves as โHENโ nodes. Sorry that we probably canโt be of any better help here.
So, weโve built yet another series of firmware images from the vanilla upstream sources plus PSRAM-fixes plus CONFIG_FREERTOS_UNICORE and made them available on our package server. The respective build for the GPy can be found at [1].
While this is totally a trial-and-error thing without much substance behind, we will be happy to hear back from you about this, @poesel.
Again no joy. @Andreas - even with the discussed modifications. It even went back to crashing after the imports.
Something is really broken here. Hopefully its the softwareโฆ Iโll have to wait until Espressif and/or Pycom will sort it out.
may we humbly ask you to try [1] again. It includes some additional fixes on the ESP-IDF level. If we are lucky, they might actually help here. For more details, enjoy [2].
the Pycom engineers recently published Pycom Firmware Release 1.20.2 (thanks!). I have spotted an update specifically related to BLE.
If we are lucky, this fixes the "bad00bad bad00bad bad00bad" errors you have been observing. So, I am humbly asking you to try GPy-1.20.2.rc3-0.8.0-vanilla-squirrel.tar.gz in order to find out. I will be happy to receive corresponding core dumps.
