Welcome, Alex!
@Alex (Stockwaage Archive • Imkerverein Nettetal e.V.), starts publishing measurement readings. Welcome!
He is using the ESP8266 beehive scale based on Homie and is running a local Mosquitto broker with a bridge configuration for forwarding MQTT publications to swarm.hiveeyes.org. A detailed description of his setup can be found at:
Inbetriebnahme von node-wifi-mqtt-homie mit Hiveeyes Anbindung
See also:
Some impressions:
We have also been able to import some historical data from one of his bee hives since March 2015:
https://swarm.hiveeyes.org/grafana/dashboard/db/nettetal-aw-beute-1?from=20150301
See also:
Thanks, @Alex!
