Das vor Kurzem diskutierte designierte Telemetriedatenformat v2 sieht beispielsweise folgendermaßen aus. Es gibt zwei Varianten – weiterhin eine kompakte und eine ausführliche.
Variante 1 – kompakt
"meta": {
"version": "2.0.0",
"time": "({RFC3339} | {Unixtime})",
"geohash": "u33dbtdck",
"location": "Out in the woods near Wedding, Berlin, Germany"
"system": {
"mcu.memfree": 2291968,
"mcu.temperature": 42.42,
"wifi.rssi": -75
"observations": {
"humidity.outside": 33.46,
"temperature.outside": 22.67,
"temperature.inside": 23.5,
"temperature.lane:1": 22.67,
"temperature.lane:2": 22.67,
"temperature.lane:3": 22.67,
"temperature.lane:4": 22.67,
"weight": 42.42
Variante 2 – ausführlich
"meta": {
"version": "2.0.0",
"system": [
{"name": "mcu.memfree", "unit": "bytes", "value": 2291968},
{"name": "mcu.temperature", "unit": "celsius", "value": 42.42},
{"name": "wifi.rssi", "unit": "decibel", "value": -75}
"observations": [
{"name": "humidity.outside", "unit": "percentage", "value": 33.46},
{"name": "temperature.outside", "unit": "celsius", "value": 22.67},
{"name": "temperature.inside", "unit": "celsius", "value": 23.5},
{"name": "temperature.body:1", "unit": "celsius", "value": 22.67, "description": "Temperatur Brutraum 1"},
{"name": "temperature.body:2", "unit": "celsius", "value": 22.67, "description": "Temperatur Brutraum 2"},
{"name": "temperature.super:1", "unit": "celsius", "value": 22.67, "description": "Temperatur Honigraum 1"},
{"name": "temperature.super:2", "unit": "celsius", "value": 22.67, "description": "Temperatur Honigraum 2"},
{"name": "temperature.lane:1", "unit": "celsius", "value": 22.67, "description": "Temperatur Wabengasse 1"},
{"name": "temperature.body:1.lane:5", "unit": "celsius", "value": 22.67, "description": "Temperatur Brutraum 1, Wabengasse 5"},
{"name": "weight:1", "unit": "kilogram", "value": 42.42}
