Pycom Pygate 8-channel LoRaWAN gateway
Source: Pycom Pygate
Power Options: Stand-Alone, With Power Over Ethernet (PoE)
Description
FIRST 5000 PYGATE UNITS AVAILABLE FOR PRE-ORDER. SHIPPING JUNE/JULY 2019. NEXT BATCH LATE Q3 2019
Pygate is Pycom’s latest hardware tech portfolio addition.
This is a new super low-cost 8-channel LoRaWAN gateway that comes in the shape of a shield. It’s got the well-known form factor from our other shields and you can connect your much loved WiPy3, LoPy4 or a GPy to it. Hook in your Pycom development boards up and you have yourself a nifty little decentralized IoT network in one go. Pygate also fits inside the Universal IP67 Case so you don’t have to limit yourself to indoors.
Connect a WiPy3, LoPy4 or a GPy to this shield and then hook in all your other Pycom devices and you have yourself a nifty little decentralised IoT network in one go.
Check out the optional Power over Ethernet via daughter board. Coming soon
Features
  • Dual SX1257 transceivers for a total of 8 channels support
  • Frequencies: 863-870 MHz and 902-928 MHz
  • Baseband processor: SX1308
  • Compatible with WiPy3.0, GPy and LoP4. Not compatible with FiPy.
  • Ultra-low power standby mode
  • Ethernet with PoE via the optional daughter board
  • Powered via USB, LiPo Battery and Ethernet via the optional daughter board
  • LiPo battery charging via the USB port
  • USB to serial connection for the Pycom module with auto-programming features
  • Dimensions: 65 (W) x 50 (L) x 8 (H) mm
    (Same small form factor as the Expansion Board v3.0/v3.1)
  • Fits the universal IP67 Case for outdoor use
PoE Adapter Specification
  • PoE (Power Over Ethernet) with 1.5A current delivery.
  • It can provide power for the Pygate and the Pycom module attached to it.
  • 10BASE-T and 100BASE-TX Physical Layer Support
  • Auto-Negotiation: 10/100 Mbps Full- and HalfDuplex
  • Plug and play compatibility with Pygate.
  • Works transparently using the TCP/IP stack embedded into our MicroPython modules.
  • Dimensions: 21 (W) x 55 (L) x 32 (H) mm
Note: This is optional.
Price
€49.95 – €69.95
Resources
Hab mir ja schon länger eines bestellt, just for documentation:
  • 2019-03-17, PRE-ORDER. SHIPPING JUNE/JULY 2019
  • 2019-06, stand mal was von August
  • 2019-08-01, PRE-ORDER. SHIPPING LATE SEPTEMBER 2019.
  • 2019-10-17, PRE-ORDER. SHIPPING around mid-December.
  • 2020-02-03, in einem Tweet von pycom von der TTN-Konferenz für März angekündigt
… Hauptsache wir bekommen es vor BER-Fertigstellung.
finally:
22 Jul 20 11:24 AM - Shipment delivered - BERLIN,GERMANY
Hat leider nicht geklappt, klarer Gewinner ist der Flughafen Berlin-Brandenburg! Aber …
Your Pycom order is now complete
Pygate ** PRE-ORDER NOW ** - Stand-Alone
shipped on July 20, 2020
Mit was wirst du das Pygate kombinieren?
Ich betreibe hier seit einem guten Jahr ein Singlechannel Draguino Gateway - aber eigentlich will ich hin zu einem kompletten 8 Kanal Gateway.
Der Preis ist gut (100€) mit z.B. WiPy.
Die Konfiguration sieht überschaubar aus: documentation (Pycom)
Mittlerweile ist das PyGate bei mir angekommen und läuft mit einem WiPy ganz ordentlich, erstes setup entlang der Doku unter Tutorials > PyGate.
Allerdings möchte ich das LoRa gateway mit einem GPy und LTE backhaul betreiben. Dazu gibt es auch code, allerdings nicht von PyCom, sondern nur aus dem Forum Pycom-SSO - LogIn.
Nachdem PyCom schon 2019 das oben verlinkte Video gedrekt hat wie einfach das mit dem Wechsel von WLAN zu LTE ist fällt ihnen nun plötzlich (nach einem Jahr potentielle Testzeit!!) auf, dass es doch nicht so problemlos geht.
We are currently investigating the case of being connected to the LTE network for longer periods of time. It appears the network or the modem drops the connection after a random amount of time. Of course we should be able to detect this and recover. It is not a common use case to be connected through LTE-M or NB-IoT 24/7, but for the pygate this is necessary.
Es ist einfach wieder mal peinlich und PyCom shipped wieder mal hardware mit bananaware, bzw. stellt für ein beworbenes feature einfach mal gar keinen code zur Verfügung.
Danke für die informative Antwort.
Das Pygate im Gehäuse mit Ethernet paßt mir preislich. Muss die Stromversorgung über PoE erfolgen oder funktioniert es auch mit einem externem Netzteil? Möchte ungern PoE in meinem Netz haben. Funktioniert das Ethernet-Module dann noch?
Ist die Software included oder muß diese noch übertragen werden?
Gerade gelesen, es geht auch über USB. Frage bleibt, funktioniert dann Ethernet ohne PoE-Versorgung?
Das PoE kommt mit dem Ethernetmodul, das Ethernet mit dem PoE-Modul; es ist dasselbe Extra-Board. Du kannst dieses Modul auch nur für den Ethernet-Anschluss verwenden wenn da kein PoE drauf ist. (Ich empfinde PoE halt als Feature.)
(Solltest Du jemals in Versuchung geraten doch mal PoE an /dieses/ Board zu halten; guck tief in die Anleitung! Da verbieten sich dann diverse andere Kontakte zu Ground/Masse/Erde zeitgleich.)
Wenn “nur USB-Strom & WLAN” für Dich ne Option ist, ist es vermutlich die einfachste und günstigste. Software ist da nicht drauf, auf dem Board ist “solo” auch keine MCU. Du musst Dir also schon auch nen LoPy/WiPy/Pycom-Gerät dazuholen. (Aber /keinen/ FiPy!)
Hier gehts zum Tutorial:
https://docs.pycom.io/tutorials/expansionboards/pygate/
