How to Visualize FFT Data in Grafana
Non-Grafana Examples
You can easily plot the output from a FFT as lines with the Arduino IDE and the Serial Plotter feature as we did it here for different sinus tones:
But this is not nice and hard to read.
We used also the Sonic Visualiserer to get FFT data from MP3:
This is an example from Spectrogram.py used in an Adafruit Tutorial.
See more examples in the thread Sound Visualization
Grafana
We have to investigate if this Grafana plugins can make an appropriate graph from a FFT data output with – let’s say 128 bins! This are 128 singel numbers for one point in time. Each number represents a frequency range.
see also this page with more details and a more fittng example figure: Heatmap Panel | Grafana Documentation
3 posts were split to a new topic: Erste Analyse der Audio-Daten des BeABee-Projekts
You can find some practical examples / charts produced with the default Heatmap Plugin for Grafana by @Diren in the thread Erste Analyse der Audio-Daten des BeABee-Projekts
I’ve tried to rebuild Diren’s heatmap graph but I struggeled
https://swarm.hiveeyes.org/grafana/d/xrIkDySGk/hiveeyes-open-hive-testdrive-test-fft-3?tab=queries&panelId=11&edit&fullscreen&orgId=2&from=1597316497803&to=1597316623670
Import via Historische Daten im CSV-Format importieren
echo '## Date/Time,bin-1,bin-2,bin-3,bin-4,bin-5,bin-6,bin-7,bin-8,bin-9,bin-10,bin-11,bin-12,bin-13,bin-14,bin-15,bin-16,bin-17,bin-18,bin-19,bin-20,bin-21,bin-22,bin-23,bin-24,bin-25,bin-26,bin-27,bin-28,bin-29,bin-30,bin-31,bin-32,bin-33,bin-34,bin-35,bin-36,bin-37,bin-38,bin-39,bin-40,bin-41,bin-42,bin-43,bin-44,bin-45,bin-46,bin-47,bin-48,bin-49,bin-50,bin-51,bin-52,bin-53,bin-54,bin-55,bin-56,bin-57,bin-58,bin-59,bin-60,bin-61,bin-62,bin-63,bin-64,bin-65' | http POST https://swarm.hiveeyes.org/api/hiveeyes/open-hive-testdrive/test-fft/3/data Content-Type:text/csv
and
cat data-test-fft_01.txt | http POST https://swarm.hiveeyes.org/api/hiveeyes/open-hive-testdrive/test-fft/3/data Content-Type:text/csv --timeout 500
Data example
2020-08-13 13:01:38.826,16095,434716,281880,0,80264,0,46340,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,
2020-08-13 13:01:38.826,16111,361934,231704,0,65535,0,46340,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,
2020-08-13 13:01:38.826,16127,314299,196607,0,65535,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,
2020-08-13 13:01:38.845,16143,270211,173391,0,46340,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,
2020-08-13 13:01:38.845,16159,167084,103621,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,
2020-08-13 13:01:38.845,16175,122606,65535,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,
2020-08-13 13:01:38.845,16191,103621,65535,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,
2020-08-13 13:01:38.845,16207,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,
2020-08-13 13:01:38.845,16223,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,
2020-08-13 13:01:38.845,16239,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,
2020-08-13 13:01:38.856,16255,65535,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,
2020-08-13 13:01:38.856,16271,122606,80264,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,
Na die Haupt-Challenge heisst in meinen Augen, dass man dem Grafanading erstmal einreden muss, dass die Y-Achse und die Y-Werte GENAU NIX MIT NEM KLASSISCHEN WERT zu tun haben. Wir kommen ja selber mit Buckets. 1 bis n. Welche Wertebereiche die Abdecken kann der Grafana ja nicht mal ahnen. (Wir wollen auch nicht beim Query ĂĽber existente Daten dynamsich Buckets erzeugen (Histogram), sondern ham die Buckets ja schon.)
Und genau dafür gibts in den Visulization-Settings zum Heatmap-Panel den Haken Format: "Time series buckets" (statt nur “Time series”). So. Und bislang hast Du in Deinem Panel ja nur ein Bucket (bin-6) gequeried. Statt jetz für jedes Bucket nen eigenen Query auszuführen, machen wir uns mal die Eigenschaft zu nutze mit einem Query auch mehrere Felder (alle 65 explizit benannt) zeitgleich zu requesten.
Et voila:
