Experience with different load cells
3.3 V vs. 5 v or x V is not a problem for the load cell. The load cell is more or less a resistor and will work with 3.3 V also.
But some breakout boards for load cells are working on the edge of the specification or below in case there are designed for 5 V systems, see Stromversorgung HX711 - #16 by Andreas
You will always have to use a load cell amp, but this is not for the excitation voltage but amplifies the signal from the load cell to the microcontroller. The load cell signal is in the mV range, so a normal Arduino / ESP can not handle such a small signal with the built-in ADC. You need an external PGA and the load cell ICs also have an ADC with higher resolution.
