WhiteCat ESP32 N1 LORA
– Source: Whitecat ESP32 N1 board - Whitecatboard.org
The Whitecat ESP32 N1 integrates an Espressif’s ESP32 MCU and a LoRa WAN transceiver in one board. The ESP32 MCU is the successor of the popular ESP8266, and integrates a lot of peripherals, Wi-Fi and Bluetooth. All this, with the onboard LoRa WAN transceiver, places the N1 as an ideal platform to deploy real IOT use cases, in both outdoor and indoor environments.
Features
  • Dual-core Tensilica LX6 microprocessor
  • Up to 240MHz clock frequency
  • 520kB internal SRAM
  • Integrated LoRa WAN transceiver working in the 868 (EU) Mhz / 915 (USA) Mhz, with onboard antenna, and UFL connector for external antenna
  • Integrated 802.11 BGN WiFi transceiver, with onboard antenna, and UFL connector for external antenna
  • Integrated dual-mode Bluetooth (classic and BLE)
  • 3.3 to 5.5V operating range through input voltage regulator
  • Second voltage regulator for power on / power off sensors through a dedicated GPIO
  • Peripherals: SPI, I2C, I2S, SDIO, UART, CAN, ETHERNET, IR, PWM, DAC, ADC.
  • RTC clock
  • 4MB Flash memory
  • Small form-factor: 78 x 26 mm
Reference
Lua RTOS
Review
