TinyPICO
TinyPICO is the world’s smallest, fully-featured ESP32 development board, designed to unlock the power of the ESP32’s dual-core 240MHz and internet connectivity, in a package smaller than your thumb!
Why
Description
  • Specs: We have filled every nook on this board, packing a massive 700mA 3.3V regulator, on-board battery management, an RGB LED, 4MB of extra PSRAM and 14 GPIO. TinyPICO is tuned for ultra low current use, dropping as low as 20uA when in deepsleep.
  • Pinout: We took great care in our GPIO selection both for internal use and broken out pins so you don’t have to worry.
  • Size: At only 18x32mm and 18x35mm, TinyPICO is the worlds smallest, fully featured ESP32 development board. It’s also very breadboard friendly, offering lots of room on either side.
Specifications
  • Processing
    • 32-bit dual-core processor operating at 240 MHz
    • 4 MB SPI flash
    • 4 MB extra PSRAM
  • Wireless
    • 2.4 GHz Wi-Fi - 802.11b/g/n
    • Bluetooth BLE 4.2
    • 3D antenna
  • Power
    • 700 mAh 3.3 V LDO regulator
    • Optimized power path for low-power battery usage
    • LiPo battery management
    • Battery pads on the bottom support both JST PH & MicroBlade connectors (included unassembled with every TinyPICO)
    • Power (red) & charge (orange) LEDs
  • Form-factor
    • Breadboard-friendly
    • Oh, it’s tiny! Just 18 mm x 32 mm
    • Product Weight: 2.0g / 0.1oz
  • Connectivity
    • 14x GPIO broken out to standard pitch headers
    • USB + serial/UART for programming
    • APA102 RGB LED
  • Control
    • MicroPython pre-installed
    • Supports Arduino IDE
    • Supports Espressif IDF
    • Lots of example code and libraries
Details
Optimised Power Paths & Deep Sleep Current
Open Source
Licenses
  • Hardware: CERN
  • Software: MIT
Resources
Documentation
In the press
TinyPICO V2
Within its New Products 2/3/2021 blog post, Adafruit presents the TinyPICO – ESP32 Development Board – V2.
https://www.tinypico.com/
Deep sleep has been optimised for all development platforms, and though we have seen it go as low as 10 uA, our official current rating in deep sleep is 20 uA.
Das hört sich ja nicht schlecht an, kommt ja an den WiPy ran Low power ESP32: Software tweaking (less hardware) - #4
