TinyLoRa is a LoRa node based on the SAM R34/R35 Low Power LoRa® Sub-GHz SiP together with an Adafruit Feather style breakout board. The CPU is a SAML21 Cortex-M0 integrated with the SX1276 in one chip.
Specs
- ATSAMR34J18 LoRA System-in-Package (SiP) based RF module
- ARM Cortex M0+ MCU & LoRa Radio
- 256KB Flash, 40 KB RAM
- Power Output: 20.00(dBm) (DS value, real output is not tested)
- Frequency Range: 862 to 1020 MHz (DS values)
- Sleep Current: 790 nA (DS value for the SiP, module will be thoroughly tested soon)
- IO pins: 27
- Module Dimenions: ~16.5x14x2 mm
