The ExpLoRer is a development/evaluation tool intended for the evaluation of Microchip wireless modules in a research and development laboratory environment. It is not a finished appliance. Manufacturers who integrate ExpLoRer in a finished appliance product must take responsibility to follow regulatory guidelines, for example for CE marking.
Features
- Atmel SAMD21, 32 bits ARM Cortex M0+ microcontroller
- Microchip RN2483A OR RN2903 LoRa module
- Microchip RN4871 Bluetooth 4.2 module (BLE) with ceramic antenna
- Atmel ATECC508A crypto chip to securely store your LoRa keys.
- Atmel SST25PF040C serial flash chip (4Mbit)
- MCP 73831 Charge controller and on-board rechargeable coin cell battery
- embedded (PCB) LoRa antenna
- MCP9700 temperature sensor
- RGB LED
- Micro USB Connector
Specifications
Microcontroller | ATSAMD21J18, 32-Bit ARM Cortex M0+ |
Compatibility | Arduino M0 Compatible |
Size | 93 x 55 mm |
Operating Voltage | 3.3V |
I/O Pins | 20 |
Analog Output Pin | 10-bit DAC |
External Interrupts | Available on all pins |
DC Current per I/O pin | 7 mA |
Flash Memory | 256 KB and 4MB (external flash) |
SRAM | 32KB |
EEPROM | Up to 16KB by emulation |
Clock Speed | 48 MHz |
Power | 5V USB power and/or 3.7 LiPo battery |
Charging | Solar charge controller, up to 500mA charge current |
LED | RGB LED, Blue LED |
LoRa | Microchip RN2483A Module |
Bluetooth | Microchip RN4871 Module |
Cyptochip | ATECC508A |
Temperature sensor | MCP9700AT |
USB | MicroUSB Port |
