[Sammlung] Stromsparmaßnahmen für den Pycom Fipy
Neben Stromsparmaßnahmen für die MicroPython-Firmware im Batteriebetrieb sowie LTE-Modem des Pycom FiPy komplett stilllegen gibt es noch ein paar andere Möglichkeiten.
Strom sparen mit Expansion Board
2018
Since you are using a regular expansion board, the flow control lines can interfere with the communication between the FiPy and the cellular modem. Can you remove the RTS and CTS jumpers on expansion board and run your tests again?
Pycom-SSO - LogIn
Remove the RTS, CTS and LED jumper as suggested in other post.
LoPy 4 - Current consumption and Deep Sleep | Pycom user forum
2018 / 2019
I have the GPy on the Expansion board (v2.1) and the LED, RTS and CTS jumpers are removed.
Power Consumption Issue | Pycom user forum
https://forum.pycom.io/topic/4224/expansion-board-3-0-power-consumption
Power consumption of the USB/UART bridge
Connecting over USB you’ll see an added, constant, power consumption from the USB-Serial chip (Expansion 2) or PIC micro (Expansion 3) as well as the USB LED.
All radios on by default | Pycom user forum
I now see a substantial drop in current after powering the device through the VIN. Thanks!
The current went down to 11mA, which is just the power consumption of the USB/UART bridge.
G01 power consumption | Pycom user forum
More Strom sparen
25. April 2017
21. Dezember 2017
16. Februar 2018
20. April 2018
23. April 2018
When I start my program I first turn off all unwanted radios (current drawn with LTE, Bluetooth etc on is around 260 mA). When they are turned off the idle (no radios) current is around 65-70 mA, which correlates good with whats written in the specs for FiPY.
19. September 2018
https://forum.pycom.io/topic/3763/battery-consumption-in-datasheet
29. November 2018
https://forum.pycom.io/topic/4057/lte-deinit-dettach-false-with-machine-deepsleep
10. Dezember 2018 ff.
Diese Diskussion zwischen v.a. Daniel Campora und Robert ist hochinterssant, v.a. wird hier mal richtig gemessen.
14. Februar 2019
8. Mai 2019
Mai / Juni 2019
https://forum.pycom.io/topic/4877/deepsleep-on-batteries
Background information about the switching regulator
Hier geht es auch aktuell wieder im Pycom-Forum um ähnliche Dinge bzgl. Stromverbrauch.
