No. I leave it to Andreas
This looks interesting
Guru Meditation Error: Core 1 panic'ed (Cache disabled but cached memory region accessed)
Guru Meditation Error: Core 1 panic'ed (IllegalInstruction). Exception was unhandled.
I found this discussion https://github.com/espressif/arduino-esp32/issues/855 , perhaps it helps.
Dear Pascal,
thanks for sharing GitHub - pascalschaefer/investigating-core-panics. However, it is not quite a small code base.
May I ask whether you are using FatFS or LittleFS already?
With kind regards,
HI @Andreas
Yes we are using LiffleFS already.
Hi @clemens
Thanks a lot for the link. Once the Timer.Alarm gets called, indeed a lot of Code is executed.
I donât have enough knowledge what is going on under the hood in detail, but the approaches in the link makes sense. So in our case it is maybe more a interrupt related problem. I will try out. I will enable a flag and execute the Time Synchronization in the Main loop via flags and check whether it helps.
Thanks for all your help.
Best Regards, Pascal
For your information, I have modified the code to only set a flag in the Timer.Alarm part and move the logic to the main threat. Because the Core Dump is still thrown, we can exclude a problem related to interrupts. Next point I can imaging is the main threat and the worker threat for sending events in parallel. Maybe a stack size problem. Memory I have checked, seems to be fine.
_thread.stack_size(64536)
self._publisherThread = _thread.start_new_thread(self.sendPendingEvents, ())
_thread.stack_size(0)
Just a note: See also Firmware Release v1.20.1 | Pycom user forum ff. re. LoRa-Stack intrinsics, respective OnRadioRx/OnRadioTx interrupts and timer interrupts.
Probably also related.
Dear Pascal,
I am only now seeing that you are actually using pure LoRa instead of LoRaWAN.
While investigating another Guru Meditation Error | Pycom user forum, I just found this piece within the Listen-before-Talk (LBT) implementation.
Maybe LoPy4-1.20.1.r3-0.8.0-vanilla-squirrel-unicore.tar.gz works better within this scenario.
With kind regards,
Edit:
Of course, this is nonsense. While the LoRa interface is initialized that way first, it will get reinitialized later to use LoRaWAN:
Dear Pascal,
the Pycom engineers recently published Pycom Firmware Release 1.20.2 (thanks!). I have spotted two updates specifically related to LoRa.
If we are lucky, this fixes the "bad00bad bad00bad bad00bad"
errors you have been observing. So, I am humbly asking you to try LoPy4-1.20.2.rc3-0.8.0-vanilla-squirrel.tar.gz in order to find out. I will be happy to receive corresponding core dumps.
Thanks already and with kind regards,
Dear @Andreas
Thanks for all your help. Today is a good day!
I tried the new build LoPy4-1.20.2.rc3-0.8.0-vanilla-squirrel.tar.gz and not any "bad00bad bad00bad bad00bad"
Core Panic happened till now.
All tests which produced earlier in all cases a Core Panic, are running now successfully without any crash. Also the full firmware doesnât crash anymore and is running stable with intensively usage of adding Events and Time Synchronization since 2 hours. I let the device run to get some long term observation.
Many thanks to you and all people involved!
Dear @Andreas
Thank you for the work being done to track down the cause for the random core panics.
We are currently running a LoPy 4 on Pycomâs v1.20.0.rc13 firmware. We are experiencing random core panics after a Lora packet is sent. Usually, the packet is successfully sent, but immediately afterwards the core panic occurrs. We have been able to catch a couple of core dumps, which unfortunately I cannot attach to this post because I am a new user. In what way could I send these to you?
Here is the version currently running on our LoPy4: (sysname=âLoPy4â, nodename=âLoPy4â, release=â1.20.0.rc13â, version=âv1.9.4-94bb382 on 2019-08-22â, machine=âLoPy4 with ESP32â, lorawan=â1.0.2â, sigfox=â1.0.1â)
Here is the first section printed out after the core panic:
Core 1 register dump:
PC : 0x40114bb0 PS : 0x00060734 A0 : 0x80085755 A1 : 0x3ffc1360
A2 : 0x00000002 A3 : 0x3ffcb728 A4 : 0x00000000 A5 : 0x00dbaa05
A6 : 0x3ffcc784 A7 : 0x00000001 A8 : 0x80084a0e A9 : 0x3ffc1340
A10 : 0x00dbaa05 A11 : 0x3ffc1361 A12 : 0x3ffc1361 A13 : 0x3ffcc7e0
A14 : 0x3ffcc7d0 A15 : 0x3ffae270 SAR : 0x0000000e EXCCAUSE: 0x00000007
EXCVADDR: 0x00000000 LBEG : 0x4009c146 LEND : 0x4009c155 LCOUNT : 0x00000000
Core 1 was running in ISR context:
EPC1 : 0x40084507 EPC2 : 0x00000000 EPC3 : 0x00000000 EPC4 : 0x40114bb0`
Do you know if Pycomâs new firmware, v1.20.2.rc3, might help to mitigate these issues?
Dear Dan,
Pycom just released 1.20.2.rc6. Weâve built upon that and updated our series of Squirrel firmware for Pycom/ESP32. So, please try the latest and greatest LoPy4-1.20.2.rc6-0.10.0-vanilla-squirrel.tar.gz while reading the installation instructions carefully.
You will be able to submit a core dump by putting it into a .txt
file and attaching it to a post by just drag & drop. If this doesnât work, please use the private messaging feature. Please also make sure you are submitting the exact version of the firmware you have been using to capture the core dump.
With kind regards,
@Andreas thank you. Is there specific advantages to using LoPy4-1.20.2.rc6-0.10.0-vanilla-squirrel.tar.gz over Pycomâs own 1.20.2.rc6? Or even 1.20.0.rc3? I am asking this because it would be easier for us, for production purposes, to be able to use Pycomâs firmware as we must flash this on dozens of devices.
I will however try both, and come back with results when I have completed the tests. The core panics are somewhat infrequent in our case, sometimes happening after at least 12 hours of operation. And as I said, they appear to occurr always after a LoRa packet is sent.
Best wishes,
Dan
Yes there are. Iâve outlined some details at about the Squirrel builds already and I am currently investigating more things where others are still reporting about occasional core panics.
Thanks!
I hear you, others are reporting similar things. Itâs sad but true!
Dear @Andreas
We have been testing Pycomâs own v1.20.2.rc6 (not your Squirrel builds yet) on our LoPy4, and I am pleased to inform you that for the past 2 days that we have had a test unit running, we have not encountered any random core panics/resets. In the past, two days of continuous opertion would cause at least 1 random core panic, if not a couple.
One important change we had to do to the code was to add a 10 ms delay within our main loop, because when moving from v1.20.0.rc13 to v1.20.2.rc6, threads did not execute if the main thread didnât yield for a short time at least (see [1]).
I donât know, then, if the cause for the random core panics was us not having this short delay in our code, or the new firmware version, or a combination of both. Regardless, we are content.
One last question: Would you be able to shed some light on the problems/bugs Pycomâs implementation of LittleFS appears to have? We are thinking of moving to this filesystem (we are using FatFS in all our units) because we have noticed that data in NVRAM and the SD card is getting corrupted (and possibly causing the LoPy4 to hang infinitely), but we are skeptical of making the change because you had mentioned bugs in Pycomâs implementation of LittleFS. Any light you could shed on this?
Thanks in advance!
Best wishes,
Dan
[1] Main thread blocks auxiliary threads (_thread module) | Pycom user forum
Hi @d.alvrzx,
Thanks for letting us know!
Thanks again for sharing your insights!
Sure. We have listed all changes on Squirrel firmware for Pycom/ESP32. The mitigations specific to LittleFS can be found at Fix core panics: Don't use m_malloc and gc_malloc unintended by amotl ¡ Pull Request #418 ¡ pycom/pycom-micropython-sigfox ¡ GitHub.
With kind regards,
Dear @Andreas
As always, Iâd like to thank you for your continued support. We are now in the middle of a 1 week stability test to see if we can run throughout this time without any resets. Hoping for the best.
In any case, weâll keep in touch. Thanks for everything.
Best regards,
Dan
Dear @Andreas , i currently try working with a PYCOM-Lop4 but pycom release crash very often, i currently try 1.20.2.rc6-0.10.1-vanilla-squirrel and have some crash too. Please can you give me some advice about the attached coredump trace ?
Thanks
[ sorry as i am a new user i canât attach a file ]
rst:0x7 (TG0WDT_SYS_RESET),boot:0x17 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
mode:DIO, clock div:1
load:0x3fff8020,len:8
load:0x3fff8028,len:2140
ho 0 tail 12 room 4
load:0x4009fa00,len:19740
entry 0x400a05bc
Pycom MicroPython 1.20.2.rc6-0.10.1-vanilla-squirrel [v1.20.1.r2-120-g201315f4a-dirty] on 2020-03-02; LoPy4 with ESP32
>>> execfile('main.py')
WLAN off
Pytrack Started
self.thread None
Not yet joined...
Not yet joined...
Not yet joined...
Joined
GPS Started
Timer Started
Guru Meditation Error: Core 1 panic'ed (LoadProhibited). Exception was unhandled.
PC : 0x4010a353 PS : 0x00060b30 A0 : 0x800e0e3c A1 : 0x3ffb5440
A2 : 0x00000001 A3 : 0x00000001 A4 : 0x00000000 A5 : 0x00000001
A6 : 0x00000000 A7 : 0x000015e9 A8 : 0x8010919e A9 : 0x3ffe14b0
A10 : 0x00000001 A11 : 0x00000001 A12 : 0x3f94ed00 A13 : 0x3ffc9448
A14 : 0x3ffe1590 A15 : 0x3ffe14f0 SAR : 0x00000011 EXCCAUSE: 0x0000001c
EXCVADDR: 0x00000001 LBEG : 0x40093708 LEND : 0x40093736 LCOUNT : 0xffffffff
ELF file SHA256: 0000000000000000000000000000000000000000000000000000000000000000
Backtrace: 0x4010a353:0x3ffb5440 0x400e0e39:0x3ffb5460 0x40117120:0x3ffb5480 0x40101ae1:0x3ffb54a0 0x400fdf05:0x3ffb54c0 0x400fdf95:0x3ffb54e0 0x40109f4f:0x3ffb5500 0x40101bf4:0x3ffb55a0 0x400fdf05:0x3ffb5620 0x400fdf95:0x3ffb5640 0x40109f4f:0x3ffb5660 0x40101bf4:0x3ffb5700 0x400fdf05:0x3ffb5780 0x4010046c:0x3ffb57a0 0x40100489:0x3ffb57f0 0x400fdf05:0x3ffb5810 0x40108f30:0x3ffb5830 0x400e087d:0x3ffb58c0
================= CORE DUMP START =================
oEEAAAEAAAARAAAAbAEAAA==
4LL9P3Cx/T/Ysv0/
cLH9P3Cy/T+BYQAA8DD7P5BC/D/gsv0/iEL8PxQAAABAOP4/QDj+P+Cy/T8AAAAA
BQAAANyi/T9TZXJ2ZXJzACKWb6bfUggAAQAAANiy/T8AAAAAIQAGAAUAAAAAAAAA
9H/7PwAAAAAAAAAAAAAAAAsAAADUZPs/PGX7P6Rl+z8AAAAAAAAAAAEAAAAAAAAA
04hAPwAAAAB8NAlAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAHrEKw==
QDQIQM5uCUAwCQYAzAIOgDCy/T+BYQAARN37PwAAAAAA/wAAAAD/AAAAAP/ObgmA
ELL9PwEAAACBYQAA4LL9PwEAAAD+AAAAIwAGAAAAAAD//z+zAAAAAAg3CUA2NwlA
/////0A2CEABAAAArIEJQAR2+j8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAOCy/T8BAAAA/gAAACMABgAAAAAAULL9PwAAAAAAAAAA
AAAAAAD/AAAAAP8AAAAA/wAAAABwsv0/AAAAAAAAAAAAAAAAAQAAAGJK/D8AAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAfLL9PwAAAAAAAAAAAAAAAAAAAAAAAAAA
QLn7P6C3+z84ufs/
oLf7P9C4+z9crZt5vL77PyxC/D9Aufs/JEL8PxkAAACikGr62V0RjEC5+z8AAAAA
AAAAADy1+z9JRExFMABKMohl7W7/x2wAAAAAADi5+z8AAAAAIQAGAAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAADUZPs/PGX7P6Rl+z8AAAAAAAAAAAEAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAzepA==
QDQIQPbxIUAwDQYAIk8XgGC4+z8AAAAAAAAAAAAAAAAwr/s/7Nz7PyAIBgDwkfw/
AAAAAEtAAAAAAAAAdPX7PwAAAAAgDwYAAAAAAAoAAAAAAAAAAAAAABzQDkBf0A5A
AAAAAEA2CEAAAAAArIEJQGR8+D8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAP//P7MAAAAAAAAAAAAAAACwcAmAgLj7PyAAAAABAAAA
AAAAADCv+z/s3Ps/IAgGAAAAAACguPs/AAAAALRB/D8AAAAAEPr8PxhE/D8AAAAA
AAAAANC4+z8AAAAAAAAAAETd+z8AAAAAAAAAAAAAAAAAAAAAAQAAAAQAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA3Lj7PwAAAAAAAAAAAAAAAAAAAAAAAAAA
tL77PxC9+z+svvs/
EL37P0C++z8fxKoqLEL8P0i5+z+0vvs/JEL8PxkAAACvc43GcxyF77S++z8AAAAA
AAAAALC6+z9JRExFMQCJvvXXiWQDEaYAAQAAAKy++z8AAAAAIwAGAAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAKRtSA==
QDQIQPbxIUAwBQYAIk8XgNC9+z8AAAAALEL8Py9XCYAwUfs/AwAAACMABgAjAAYA
/////4xB/D8sQvw/L1cJgDBR+z8DAAAAIwAGAAAAAADQvfs/AAAAAAAAAAAAAAAA
AAAAAEA2CEAwUfs/rIEJQNSB+D8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAP//P7MAAAAAAAAAAAAAAACwcAmA8L37PyAAAAABAAAA
//8/swAAAAAAAAAAAAAAAAAAAAAQvvs/AAAAALRB/D8gAAAAEPr8PxxE/D8AAAAA
AAAAAEC++z8AAAAAAAAAAETd+z8AAAAAAAAAAAAAAAABAAAAAQAAAAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAATL77PwAAAAAAAAAAAAAAAAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA==
7Cb9P/Ak/T/kJv0/
8CT9P4Am/T+DYQAAvJ/7P9xD/T/sJv0/EEL8PxMAAADf4XALSyB/sewm/T8AAAAA
BgAAAOgW/T9Mb1JhAAA9pWvtUGwfij8AAQAAAOQm/T8AAAAAIQAGAAYAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAP7PgA==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0K37P2Cv+z+EYQAA9EX8P/Qm/T+0n/s/EEL8PwcAAAAIn/s/CJ/7P7Sf+z8An/s/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wH79P2CG/T8FYgAAGEL8P7yf+z/sRfw/EEL8Pw4AAAAoL/s/KC/7P+xF/D8AAAAA
CwAAANBW/T9NaWNyb1B5AAAAAAAAAAAAAQAAAMyG/T8AAAAAIQAGAAsAAAAAAAAA
PDX7P/ST/D8AAAAAAAAAAAAAAADUZPs/PGX7P6Rl+z8AAAAAAAAAAAEAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAgAAAA==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1EP9P8BB/T/MQ/0/
wEH9P2BD/T+CYQAA9Cb9PxhC/D/UQ/0/EEL8PxMAAAA6CFFGAS97d9RD/T8AAAAA
BgAAANA1/T9TaWdmb3gAcx7mLS7BJ/8AAAAAAMxD/T8AAAAAIQAGAAYAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAH3GGg==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wMn7P7DK+z8AAAAABEL8PwRC/D8gy/s//EH8Pw8AAABQwPs/UMD7PyDL+z9IwPs/
CgAAABzB+z9UbXIgU3ZjALpE/Lq7kQkAAAAAABjL+z8AAAAAIQAGAAoAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABIV/g==
QDQIQOF/CUAwAAYAAAAAAIDK+z8AAAAAAAAAAAAAAAAoRPw/IET8PwEAAADhfwmA
YMr7PwAAAABE3fs/fEH8PwAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
AAAAAEA2CEAAAAAArIEJQESO+D8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAESO+D8AAAAAAAAAAAAAAAAAAAAAsMr7PwAAAAAAAAAA
AAAAAAAAAAC8yvs/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
AAAAAAAAAAA=
rMX9PxDE/T+kxf0/
EMT9P0DF/T8o7wWXOHz7P8yy+z+sxf0/oEH8PxQAAABnN4FYI0J2+qzF/T8AAAAA
BQAAAKi1/T9Tb2NrZXQgT3BlcmF0aW8AAQAAAKTF/T8AAAAAIQAGAAUAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAABAAAAALlEOA==
QDQIQPC/AEAwAAYA6GkJgNDE/T8AAAAAIwAGACAABgDAzfs/VQAAAECi/T///z+z
q6sAAOzc+z8jAAYArMX9PwEAAAD+AAAAAAAAAAAAAAClpaWlpaWlpQAAAAAAAAAA
AAAAAEA2CEABAAAArIEJQNSI+j8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAADuegmA4MT9P0Td+z8GAAAA
el8OgADF/T8BAAAAHET8P6zF/T8BAAAA/gAAANCD/T8AAAAAIMX9PwAAAAAAAAAA
GET8P0Td+z+MQfw/kEL8PwAAAABAxf0/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAATMX9PwAAAAAAAAAAAAAAAAAAAAAAAAAA
MHz7P7Cc+z84nvs/
sJz7P9Cd+z9sY/j/cHr7P7TF/T8wfPs/oEH8PwEAAAAEfPs/BHz7PzB8+z/8e/s/
GAAAADya+z9pcGMxAJO6RwJQ7NeQ0oQAAQAAADie+z8AAAAAIQAGABgAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACKr3Q==
QDQIQJhgCUAwBwYALB4IgHCd+z/Ye/s/AAAAACR8+z8AAAAA2Hv7PwAAAACYYAmA
UJ37PwEAAAD/////RN37PxhE/D/+AAAAIAMGABwAAAD//z+zAAAAAKw+CUC3PglA
/////0A2CEAYRPw/rIEJQGRh+D8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAETd+z8YRPw//gAAACADBgAAAAAAsJ37P+xA/D8AAAAA
AAAAAJwEAAD+AAAAIAMGAP////8AAAAA7ED8P9hA/D8kfPs/AAAAANh7+z8AAAAA
AAAAANCd+z8AAAAAAAAAALh3CEABAAAAAAAAAAAAAACQFAiAgH3+PwABAADoDQBA
AAAAAAAAAADcnfs/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
AAAAAAAAAAA=
aHr7P+B4+z9gevs/
4Hj7PwB6+z+ZMp39rLD7Pzh8+z9oevs/oEH8PwEAAAA4dvs/OHb7P2h6+z8wdvs/
GAAAAGR2+z9pcGMwAHvBDmFD/DBbvV8AAAAAAGB6+z8AAAAAIQAGABgAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAIeyyg==
QDQIQJhgCUAwAQYALB4IgKB5+z8Mdvs/AAAAAFh2+z8AAAAADHb7PwAAAACYYAmA
gHn7PwAAAAD/////RN37PxhE/D/+AAAAAQAAAAAAAAAAAAAAAQAAAAAAAAAAAAAA
AAAAAEA2CEAYRPw/rIEJQJQ9+D8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAP//P7MAAAAAAAAAAAAAAAAAAAAA4Hn7P+hA/D8AAAAA
AAAAADVAAAD+AAAAAQAAAP/////gefs/6ED8P9hA/D8AAAAAAAAAAAEAAAAAAAAA
AAAAAAB6+z8AAAAAAAAAALh3CEAAAAAAAAAAAAAAAAAFFAiAIDz+P4hB/D/LakA/
AAAAAAAAAAAMevs/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
pLD7PyCR/T/Qkv0/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4HD7PxBy+z/UtBzMaDT9P6yw+z98cvs/oEH8PwMAAABsQPw/bED8P3xy+z9kQPw/
FgAAAHhm+z9lc3BfdGltZXIAEGBsscIAAAAAAHRy+z8AAAAAIQAGABYAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAO20Fw==
QDQIQJhgCUAwDwYAwSQNgKBx+z9AQPw/AAAAAIxA/D8AAAAAQED8PwAAAACYYAmA
gHH7PwAAAAD/////RN37PxhE/D/+AAAA3EP9PwAAAAD/////QDYIQAg3CUA2NwlA
/////0A2CEAYRPw/rIEJQKQ1+D8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAIkYCICgcfs//Nz7P2Rf+z8AAAAA4HH7P5RA/D+cQPw/
AAAAAEBAAAD+AAAA3EP9P//////gcfs/AAAAAJxA/D8AAAAAAAAAACRw9D8AAAAA
AAAAABBy+z8AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAJxA/D9PJfsA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAHHL7PwAAAAAAAAAAAAAAAAAAAAAAAAAA
YDT9P8Ay/T9YNP0/
wDL9P/Az/T/IiDkAQMv9P4Ry+z9gNP0/oEH8PxEAAAC8Yvs/vGL7P2A0/T+0Yvs/
CAAAAFwo/T9Mb1JhX1RpbWVyX2NhbGwAAQAAAFg0/T8AAAAAIQAGAAgAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAFp8w==
QDQIQJhgCUAwCgYAFBYRgIAz/T+QYvs/wDP9P9xi+z8AAAAA5GL7PwAAAACYYAmA
YDP9PwEAAAD/////RN37PxhE/D/+AAAAAQAAABEAAAABFhGAoDP9Pwg3CUA2NwlA
/////0A2CEAYRPw/rIEJQIT3+T8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAACAAAAAHAAAAAwAAAGQE/D8AAAAAwDP9P3ib/D8AAAAA
AAAAAPJVAAB4m/w/AAAAAP/////AM/0/eJv8PwAAAADcYvs/AAAAAPhi+z8BAAAA
AAAAAPAz/T8AAAAAAAAAAFjOEUAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA/DP9PwAAAAAAAAAAAAAAAAAAAAAAAAAA
OMv9P5Dq/T+k7P0/
kOr9P0Ds/T+lpaWlYC/7P2g0/T84y/0/oEH8Pw4AAAB8tP0/fLT9PzjL/T90tP0/
CwAAAKjM/T9JUlFzAKWlpaWlpaWlpaUAAQAAAKTs/T8AAAAAIQAGAAsAAAAAAAAA
AAAAANzr/T8AAAAAAAAAAAAAAADUZPs/PGX7P6Rl+z8AAAAAAAAAAAEAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAqWlpQ==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WC/7P0BT+z9MWfs/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xLL7P0Ch/T/Uov0/
QKH9P3Ci/T8AAAAAtMX9P6hB/D/Esvs/oEH8PxQAAAAAAAAAAAAAAMSy+z8AAAAA
BQAAANiS/T9TbWFydENvbmZpZwAAAAAAAQAAANSi/T8AAAAAIQAGAAUAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAABAAAAAAAAAA==
QDQIQPC/AEAwAAYA6GkJgACi/T8AAAAAIwAGACAABgDg8Ps/AwAAACMABgD//z+z
q6sAAOzc+z8jAAYAxLL7PwEAAAD+AAAAAAAAAAAAAAClpaWlpaWlpQAAAAAAAAAA
AAAAAEA2CEABAAAArIEJQARm+j8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAADuegmAEKL9P0Td+z8FAAAA
U3EOgDCi/T8BAAAAHET8P8Sy+z8BAAAA/gAAACAAAAAAAAAAUKL9PwAAAAAAAAAA
GET8P0Td+z+MQfw/kEL8PwAAAABwov0/AAAAAAAAAAA8T/w/AAAAAAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAfKL9PwAAAAAAAAAAAAAAAAAAAAAAAAAA
================= CORE DUMP END =================
Rebooting...
Dear Eric,
Iâve just decoded the coredump for you: eric-pennamen-coredump-decoded.txt (15.8 KB)
Maybe LoPy4-1.20.2.rc6-0.10.2-vanilla-squirrel-nosmartconfig.tar.gz helps.
With kind regards,
Thanks a lot @Andreas , i have just put the firmware in test on a device and i keep you informed if i see some crach.
