Coming from Investigating ESP32 WiFi connectivity behavior, we are investigating and discussing mDNS support for Pycom MicroPython here.
Dear @roh,
This would be cool and I was thinking about that as well. However, I havenât been able to see anything at espressif.local
out of the box. May we missed some switch â research+outcome welcome! But Iâm also hesitant: While having no proof for that, I am questioning if a superfast cycle like youâve outlined with
will be able to let mdns or similar technologies enough breath to converge. Everything I can tell you from my experiments is that reaching the device using the regular espressif
hostname through a standard Fritz DNSDHCP is not reliable at all regarding quick turnaround times which I believe are essential for plug & play operations.
However, as soon as the device will be in maintenance mode, we will be happy to use just everything from the comfort zone the ESP32 might be able to offer us. Iâve somewhere read something about someone trying to do some DLNA stuff on the ESP32 â maybe with MicroPython already. Finding this again might give us some direction to follow.
Thanks for your interest, I would be happy to have you with us close to this specific topic (ongoing), especially reviewing the first important iterations of the respective implementation.
Cheers,
Itâs been this thread (without any solution fitting our current problem) on the MicroPython forum:
Interesting enough, itâs Daniel Campora who is answering back then. So, maybe we could use that to ask him on the Pycom forum these days.
We want to a) look at MicroPython in general but also currently more important to us b) at the Pycom implementation specifically.
It looks like it has been on someones wishlist already:
First, as I learned
I would like to retract that statement:
Then again,
hard-coding IPs, or scanning ports sucks
â RFC: mDNS support implementation ¡ Issue #201 ¡ micropython/micropython-esp32 ¡ GitHub
So true.
Discussions
- ESP8266 seems to have it already, right?
Candidates
- mDNS Module for MicroPython
- zeroconf ¡ PyPI â will probably not even remotely run on MPY?
See also
Why canât I just ping this widget?
This is just suitable for the CC3100, as far as we can deduce from Repository search results ¡ GitHub.
At least, itâs not a builtin on Pycomâs MicroPython:
make repl
>>> import network
>>> dir(network)
['__class__', '__name__', 'Bluetooth', 'LTE', 'LoRa', 'Server', 'Sigfox', 'WLAN']
Bummer.
@vinz is already using the MicroDNSSrv [1] at the Hiverize Datalogger for FiPy [2]. I am wondering if this might also help us for device discovery in any way? Probably not.
[1] GitHub - jczic/MicroDNSSrv: A micro DNS server for MicroPython to simply respond to A queries on multi-domains with or without wildcards (used on Pycom modules & ESP32)
[2] FiPy/webserver.py at workshop-20190528 ¡ Hiverize/FiPy ¡ GitHub
Two more things for today:
GitHub - nickovs/slimDNS: Simple, Lightweight Implementation of Multicast DNS
slimDNS: a pure Python mDNS implementation - MicroPython Forum -
mDNS capability by goatchurchprime ¡ Pull Request #14 ¡ peterhinch/micropython-mqtt ¡ GitHub
mDNS capability ¡ Issue #11 ¡ peterhinch/micropython-mqtt ¡ GitHub - See also: Telnet to esp32 ¡ Issue #191 ¡ micropython/micropython-esp32 ¡ GitHub
If Iâm not counting wrong here, the issue at [ESP32] DHCP Hostname not working correctly ¡ Issue #4748 ¡ micropython/micropython ¡ GitHub seems to reflect that well.
So, we will be happy to check out mDNS capability by goatchurchprime ¡ Pull Request #14 ¡ peterhinch/micropython-mqtt ¡ GitHub within one of the next iterations on the datalogger code.
Thanks again for bringing this up, @roh.
There have been some news about this within the development of Genuine MicroPython coming from the https://github.com/micropython/micropython/issues/4821.
It looks like the most recent Pycom firmware release 1.20.1.r3 available through GitHub - pycom/pycom-micropython-sigfox at Release/v1.20 adds mDNS support per
cc @roh
This thread seems to be the default one on Google when you search âmicropython mdnsâ.
Thatâs why I also wanted to put a reference to an uasyncio implementation for MDNS service discovery here: GitHub - cbrand/micropython-mdns: MDNS implementation for MicroPython with Service Discovery
This library has been tested on the ESP32 with MicroPython 1.13 and worked on a rather chatty network with a lot of mdns service announcements (mainly generated via queries with the tool mdns-scan
Thank you so much for conceiving and sharing this, Christoph!
