Bei New Firmware Release Candidate v1.20.0 | Pycom user forum ff. gibt es einige interessante Dinge nachzulesen, die u.U. Rückschlüsse zulassen, warum es mit jeweils aktuellen Firmwares zum jeweiligen Zeitpunkt u.U. nicht funktioniert haben kann.
Please note there might still be dragons.
- LTE cannot send AT commands if NB-IoT network gets unreachable · Issue #188 · pycom/pycom-micropython-sigfox · GitHub
- LTE modem becomes unresponsive - even after machine.reset() · Issue #225 · pycom/pycom-micropython-sigfox · GitHub
- https://github.com/pycom/pycom-micropython-sigfox/issues/294
- Cannot send Sigfox message when OneWire bus is being used · Issue #295 · pycom/pycom-micropython-sigfox · GitHub
- GPy and Fipy Failure to register in Rohde & Schwarz R&S®CMW500 for LTE and NB-IOT · Issue #304 · pycom/pycom-micropython-sigfox · GitHub
- Sequans modem won't attach and reports unusual AT command response - EXIT: File: rfcChar.c@107 · Issue #308 · pycom/pycom-micropython-sigfox · GitHub
Still, I believe it’s getting better overall and the modem might finally be usable in Germany already. @here: Are our pre-flight testers still with us?
News from the trenches. Completely unsorted and unscanned. Just for your reference and quick access to what is currently happening upstream on this topic.
- FiPy with NB-IoT sim cards but no signal | Pycom user forum
- Need Help to connect NB-IOT 1nce / Germany | Pycom user forum
- FiPy, Nb-IoT and Deepsleep | Pycom user forum (don’t get fooled, this is not only about deep sleep)
- NBIoT Support, lack of | Pycom user forum
- Important update regarding LTE modem updates | Pycom user forum
Just to let you know things are still in flux here – also on the carrier side.
Wenn wir Pech haben müssen wir die Module nochmal einschicken um bestimmte Bänder freizuschalten
https://forum.pycom.io/topic/3843/important-news-regarding-cat-m1-and-nb-iot-cellular-range/8
@rskoniec @Eric-Waai No, you can’t upgrade it yourself. The band information is written in an area on the modem that can only be overwritten with a production programmer and proprietary software. It is the same modem as the previous modules
Dass es die Möglichkeit gibt, dass unsere Module übers RMA müssen, wenn wir das LTE-Modem nutzen wollen, ist schon eine zeitlang bekannt. @tonke hat glaube ich auch schon einmal versucht, das RMA-Verfahren einzuleiten, ich kenne jedoch nicht den aktuellen Stand.
Vielleicht können wir das genauer prüfen und möglichst früh mit den verbleibenden Modulen das RMA-Verfahren einleiten, falls nötig.
Recap
There are discussions about whether the FiPy modules in our hands already support Band 8, which is assumed to be required for attaching to the Telekom network through iot.1nce.net
in Germany.
Details
After the discussion at Important update regarding LTE modem updates | Pycom user forum dropped off in October 2018, @robert-hh reported success around March 2019, which we already cited above, see also Erschließung von LTE Cat M1 und NB1 mit dem Pycom FiPy - #32 by Andreas.
More details
When inspecting some modules on my desktop, it appears they are running the most recent CATM1-39529 firmware for the Sequans Modem to support CAT-M1.
If you want to switch to NB1 or upgrade to more recent firmware versions, Introduction will be the right place to follow.
DIY
We will outline some AT commands picked up from the Pycom Forum to enable you checking details with your modem. We are currently running
Pycom MicroPython 1.20.0.rc11 [v1.9.4-0a38f88] on 2019-05-14; FiPy with ESP32
First, check into a REPL.
$ make repl
Then, execute some Python commands.
Check modem capabilities
from network import LTE
lte = LTE()
lte.send_at_cmd('AT!="RRC:setDbgPerm full"')
print(lte.send_at_cmd('AT!="RRC:showcaps"'))
Output
== CAPS ====================================
. access stratum: R13
. catM : 1
. nb-IoT : 0
-- EUTRA bands --
. supported : 28/20/13/12/8/5/4/3
. board : 3/4/5/8/12/13/20/28
So, this module well supports band 8, as lte.attach(band=8, apn="iot.1nce.net")
also invokes without croaking. Otherwise, you might receive things like
ValueError: band 8 not supported
Check modem firmware version I
print(lte.send_at_cmd('AT!="showver"'))
Output
SYSTEM VERSION
FIRMWARE VERSION
Bootloader0* : 5.1.1.0 [39529]
Bootloader1 : NA
Bootloader2 : NA
NV Info : 1.1,0,0
Software : 5.1.1.0 [39529] by robot-soft at 2018-09-28 16:07:40
UE : 5.0.0.0d
COMPONENTS
ZSP0 : 1.0.99-13616
ZSP1 : 1.0.99-12355
OK
Also, this is the information presented by sqnsupgrade
>>> import sqnsupgrade
>>> sqnsupgrade.info()
Output
<<< Welcome to the SQN3330 firmware updater [1.2.5] >>>
>>> FiPy with firmware version 1.20.0.rc11
Your modem is in application mode. Here is the current version:
UE5.0.0.0d
LR5.1.1.0-39529
IMEI: {redacted}
This output means that the modem is effectively running firmware CATM1-39529, which seems to be the most recent one for CAT-M1 as of 2019-07-17, see also Introduction.
Conclusion
Band 8 seems to be supported by the current configuration of the specific devices on my desktop, at least for CAT-M1. If CAT-NB1 would be the way to follow, we should revisit this.
@robert-hh and also others confirm everything should work with the newest board and the newest firmware.
But also, the hardware thing still holds true:
For me, it is actually reading “FiPy V1.2” – so all should be good if all FiPys around us come from the same batch already.
Please also be aware that
Some more commands…
lte = LTE()
Modem info
# Display DL SYNCHRO STATISTICS and SYSTEM FSM information
print(lte.send_at_cmd('AT!="showphy"'))
print(lte.send_at_cmd('AT!="fsm"'))
– LTE driver appears to be stopped? | Pycom user forum
AT-based help
# Display list of supported AT commands
print(lte.send_at_cmd('AT+CLAC'))
# Display list of all Sequans specific commands
print(lte.send_at_cmd('AT!="help"'))
# How to use the AT-based help
print(lte.send_at_cmd('AT!="help help"'))
– Important update regarding LTE modem updates | Pycom user forum
Examples
Some example commands at your service.
# Display network configuration
print(lte.send_at_cmd('AT!="ifconfig"'))
# Print network connections
print(lte.send_at_cmd('AT!="netstat"'))
# Show the system time
print(lte.send_at_cmd('AT!="showTime"'))
# Show the system logs
print(lte.send_at_cmd('AT!="showLogs"'))
print(lte.send_at_cmd('AT!="getLogs"'))
print(lte.send_at_cmd('AT!="printLogs"'))
# Print cpu information
print(lte.send_at_cmd('AT!="cpuinfo"'))
# Display memory status
print(lte.send_at_cmd('AT!="mem"'))
# Dump eCos tasks
print(lte.send_at_cmd('AT!="infoAllTask"'))
# List contents of directories in a tree-like format
print(lte.send_at_cmd('AT!="tree"'))
# Display current state
print(lte.send_at_cmd('AT!="state"'))
# Request to power on
print(lte.send_at_cmd('AT!="powerOn"'))
# Request to power off
print(lte.send_at_cmd('AT!="powerOff"'))
UCI options
UCI show Show UCI options
UCI get Get UCI option
UCI set Set UCI option
UCI delete Delete UCI option
# Show UCI options
print(lte.send_at_cmd('AT!="UCI::show"'))
# Show value of specific UCI option
print(lte.send_at_cmd('AT!="UCI::get sqnsms.generic.moSmsType"'))
Moar
print(lte.send_at_cmd('AT!="CBE::showVersion"'))
print(lte.send_at_cmd('AT!="RRC::showCaps"'))
print(lte.send_at_cmd('AT!="L1P::getDebug"'))
External resources
Habe erwartet, dass man per einfachen Software-Switch von CAT-M1 zu CAT-NB1 wechseln kann, @Ron sagte aber auch was von Modem-Firmwareupdate, weiß nicht, ob das immer sein muss, wenn man von CAT-M1 zu CAT-NB1 wechselt oder anders herum oder nur weil man in DE ein update für andere Kanäle braucht.
Bisher hatten @tonke und ich es so verstanden, dass man die Modem-Firmware je nach Betriebsart wechseln muss und dachten, das wäre bereits ins kollektive Bewusstsein übergegangen. Die drüben bei Erschließung von LTE Cat M1 und NB1 mit dem Pycom FiPy aufgeschnappten capabilities lassen auf entsprechendes schließen:
. catM : 1
. nb-IoT : 0
Im Pycom-Forum bei FiPy, NB-IoT, 1nce/ Telekom.de germany: fails, no band 8 support? | Pycom user forum finden sich allerdings Dumps von anderen, die zeigen, dass u.U. beide Varianten gleichzeitig unterstützt werden könnten. Who knows?
. catM : 1
. nb-IoT : 1
We just asked for clarification about dual-mode modem support at Connection to NB-IOT issues. How to get logs | Pycom user forum.
@robert-hh promptly answered our question. Thanks again!
Hm… stellt sich erst recht die Frage, wie andere dann im pycom-Forum dies hinbekommen haben:
Gedanken
Genau. Vielleicht haben die Entwickler bei Sequans die entsprechende auf eCos basierende Software-Implementierung aufgemöbelt und darin nun doch beide Modi zeitgleich ermöglicht. Wäre diese These an der Grenze zwischen Theorie und Praxis grundsätzlich denkbar?
Wir sollten diesem Ratschlag vermutlich folgen, die CATM1-39529 Firmware hinter uns lassen und die NB1-41019 Firmware aufspielen – v.a. vor dem Hintergrund, dass NB1 ohnehin schon zugänglicher zu sein scheint als M1. Vielleicht sehen wir dann mehr.
Vermutung: Vielleicht galt die Trennung nur für den Prototypen der Firmware Monarch LR-5.1.1.0. Mittlerweile scheint die Reisegruppe bei Monarch LR-6.0.0.0 angekommen zu sein – vielleicht aber auch nur in Form der Pycom-Kohorte als Betatester ;].
Direct download
https://software.pycom.io/downloads/sequans.html
Sequans CAT-M1 firmware
Sequans NB-IoT firmware
– German is easy! – “Die Sonne scheint zu scheinen.”
– Bananenprinzip – Wikipedia
Updated documentation for LR6.0.0.0
Die Community scheint ebenfalls auf eine neue AT-command Referenz zu warten.
https://forum.pycom.io/topic/3736/documentation-of-monarch-platform
AT+CFUN fun
A link to a historic version of a document at Pycom might give some clues
The latest Cat-M1 firmware is the following:
UE5.0.0.0d
LR5.1.1.0-36417
And this is the latest NB-IoT firmware:
UE6.0.0.0
LR6.0.0.0-37781
– Sequans Monarch SQN3330 » Firmware upgrade @ Jul 19, 2018
There’s also a snippet how the modem maybe had to be initialized when operating in NB1 mode.
However, this documentation is from 2018 so it might well be outdated.
Hier wird beschrieben, wie man die Modem-Firmware über die SD-Karte aktualisieren kann und so wie betrachtet könnte das auch zur Laufzeit funktionieren. Trotzdem Miau – will man eigentlich nicht unbedingt so machen – oder doch!?
Auf jeden Fall ist es nach dem aktuellen Stand vermutlich noch nicht so einfach möglich (oder wird es niemals sein) wie die Betriebsart einer WiFi-Schnitte von STA auf AP oder umgekehrt umzustellen.
