We haven’t actually tested this for real. However, the little example program didn’t crash the machine, which is at least something. @clemens and anyone interested: You might want to try this at home – thanks already!
Instructions
The ready-made firmware image [1] might make your life easier. The example programs [2] will have to be adjusted to use the Pycom-specific pin definition like bck_pin = Pin('P9') instead of e.g. bck_pin = Pin(32).
The following table describes the pins we use by default (Note that you can also use other pins for the same purpose).
I did not find any proofed pin definitions for the PyCom devices, so in case it is not working we may have a look at the ESP32 examples and used pins, eg. this and that.
So I will stay on the pins Andreas mentioned but in an other order due to better physically wiring:
Thanks for letting me know. Cheers! We might want to tell some people on the Pycom user forum accordingly [1].
When connecting the pins, there actually are design mistakes you would want to avoid. Regarding this, I collected the resources you referenced already and added some additional ones:
I have tested different pin combinations but sound does not get better. So I will try my Adafruit mic I have ordered a long time ago, same was used in the example and test this next (in case I will find it :-).
In the code is a comment
Testing was done with an INMP441 Microphone
but in the readme the Adafruit breakout is mentioned:
I have ordered some INMP441 mics also, really inexpensive, you can get it for 3-4 EUR at ebay. And in a nice form factor that will fit in a Lockenwickler
@clemens, @einsiedlerkrebs and me asked ourselves how processing the audio data would actually be done after ingesting it through the MicroPython I2S module. As Python will be too slow, data will have to be channeled through C-level implementations from the I2S driver to the analysis algorithm, most probably using DMA.
Seems that Mike Teachman’s read-mono-mic-write-internal-flash.pyI’ve used 2019-11 is no longer available, but you can find now an example writing to SD
Make it working on a PyCom device
First I installed Andreas’ FiPy firmware version with I2S support: FiPy-1.20.1.r1-0.7.0-vanilla-dragonfly-onewire-i2s.tar.gz, use this or a newer version.
The original code uses an other SD card interface, according to SD I changed some lines to fit it for the FiPy.
And I changed the pins for the I2S mic to:
P11 - SCK
P22 - WS
P21 - SD
This is the modified code
# The MIT License (MIT)
# Copyright (c) 2019 Michael Shi
# Copyright (c) 2020 Mike Teachman
# https://opensource.org/licenses/MIT
# Purpose:
# - read 32-bit audio samples from the left channel of an I2S microphone
# - snip upper 16-bits from each 32-bit microphone sample
# - write 16-bit samples to a SD card file using WAV format
# Recorded WAV file is named:
# "mic_left_channel_16bits.wav"
# Hardware tested:
# - INMP441 microphone module
# - MSM261S4030H0 microphone module
import os
from machine import Pin
from machine import SD
from machine import I2S
#======= USER CONFIGURATION =======
RECORD_TIME_IN_SECONDS = 5
SAMPLE_RATE_IN_HZ = 22050
WAV_SAMPLE_SIZE_IN_BITS = 16
WAV_SAMPLE_SIZE_IN_BYTES = WAV_SAMPLE_SIZE_IN_BITS // 8
MIC_SAMPLE_BUFFER_SIZE_IN_BYTES = 4096
SDCARD_SAMPLE_BUFFER_SIZE_IN_BYTES = MIC_SAMPLE_BUFFER_SIZE_IN_BYTES // 2 # why divide by 2? only using 16-bits of 32-bit samples
NUM_SAMPLE_BYTES_TO_WRITE = RECORD_TIME_IN_SECONDS * SAMPLE_RATE_IN_HZ * WAV_SAMPLE_SIZE_IN_BYTES
NUM_SAMPLES_IN_DMA_BUFFER = 256
NUM_CHANNELS = 1
# snip_16_mono(): snip 16-bit samples from a 32-bit mono sample stream
# assumption: I2S configuration for mono microphone. e.g. I2S channelformat = ONLY_LEFT or ONLY_RIGHT
# example snip:
# samples_in[] = [0x44, 0x55, 0xAB, 0x77, 0x99, 0xBB, 0x11, 0x22]
# samples_out[] = [0xAB, 0x77, 0x11, 0x22]
# notes:
# samples_in[] arranged in little endian format:
# 0x77 is the most significant byte of the 32-bit sample
# 0x44 is the least significant byte of the 32-bit sample
# returns: number of bytes snipped
def snip_16_mono(samples_in, samples_out):
num_samples = len(samples_in) // 4
for i in range(num_samples):
samples_out[2*i] = samples_in[4*i + 2]
samples_out[2*i + 1] = samples_in[4*i + 3]
return num_samples * 2
def create_wav_header(sampleRate, bitsPerSample, num_channels, num_samples):
datasize = num_samples * num_channels * bitsPerSample // 8
o = bytes("RIFF",'ascii') # (4byte) Marks file as RIFF
o += (datasize + 36).to_bytes(4,'little') # (4byte) File size in bytes excluding this and RIFF marker
o += bytes("WAVE",'ascii') # (4byte) File type
o += bytes("fmt ",'ascii') # (4byte) Format Chunk Marker
o += (16).to_bytes(4,'little') # (4byte) Length of above format data
o += (1).to_bytes(2,'little') # (2byte) Format type (1 - PCM)
o += (num_channels).to_bytes(2,'little') # (2byte)
o += (sampleRate).to_bytes(4,'little') # (4byte)
o += (sampleRate * num_channels * bitsPerSample // 8).to_bytes(4,'little') # (4byte)
o += (num_channels * bitsPerSample // 8).to_bytes(2,'little') # (2byte)
o += (bitsPerSample).to_bytes(2,'little') # (2byte)
o += bytes("data",'ascii') # (4byte) Data Chunk Marker
o += (datasize).to_bytes(4,'little') # (4byte) Data size in bytes
return o
bck_pin = Pin('P11')
ws_pin = Pin('P22')
sdin_pin = Pin('P21')
audio_in = I2S(
I2S.NUM0,
bck=bck_pin, ws=ws_pin, sdin=sdin_pin,
standard=I2S.PHILIPS,
mode=I2S.MASTER_RX,
dataformat=I2S.B32,
channelformat=I2S.ONLY_LEFT,
samplerate=SAMPLE_RATE_IN_HZ,
dmacount=50,
dmalen=NUM_SAMPLES_IN_DMA_BUFFER
# configure SD card
# slot=2 configures SD card to use the SPI3 controller (VSPI), DMA channel = 2
# slot=3 configures SD card to use the SPI2 controller (HSPI), DMA channel = 1
sd = SD()
os.mount(sd, "/sd")
wav = open('/sd/mic_left_channel_16bits.wav','wb')
# create header for WAV file and write to SD card
wav_header = create_wav_header(
SAMPLE_RATE_IN_HZ,
WAV_SAMPLE_SIZE_IN_BITS,
NUM_CHANNELS,
SAMPLE_RATE_IN_HZ * RECORD_TIME_IN_SECONDS
num_bytes_written = wav.write(wav_header)
# allocate sample arrays
# memoryview used to reduce heap allocation in while loop
mic_samples = bytearray(MIC_SAMPLE_BUFFER_SIZE_IN_BYTES)
mic_samples_mv = memoryview(mic_samples)
wav_samples = bytearray(SDCARD_SAMPLE_BUFFER_SIZE_IN_BYTES)
wav_samples_mv = memoryview(wav_samples)
num_sample_bytes_written_to_wav = 0
print('Starting')
# read 32-bit samples from I2S microphone, snip upper 16-bits, write snipped samples to WAV file
while num_sample_bytes_written_to_wav < NUM_SAMPLE_BYTES_TO_WRITE:
try:
# try to read a block of samples from the I2S microphone
# readinto() method returns 0 if no DMA buffer is full
num_bytes_read_from_mic = audio_in.readinto(mic_samples_mv, timeout=0)
if num_bytes_read_from_mic > 0:
# snip upper 16-bits from each 32-bit microphone sample
num_bytes_snipped = snip_16_mono(mic_samples_mv[:num_bytes_read_from_mic], wav_samples_mv)
num_bytes_to_write = min(num_bytes_snipped, NUM_SAMPLE_BYTES_TO_WRITE - num_sample_bytes_written_to_wav)
# write samples to WAV file
num_bytes_written = wav.write(wav_samples_mv[:num_bytes_to_write])
num_sample_bytes_written_to_wav += num_bytes_written
except (KeyboardInterrupt, Exception) as e:
print('caught exception {} {}'.format(type(e).__name__, e))
break
wav.close()
os.umount("/sd")
sd.deinit()
audio_in.deinit()
print('Done')
print('%d sample bytes written to WAV file' % num_sample_bytes_written_to_wav)
and this a quite good recording:
I got not always such a comfortable quality and I have to investigate what the reasons are. One is: you have to keep a distance of 20 cm to get a nice recording, at least for speach.
After some more testing the audio quality is really good and stable. Perhaps a wiring problem before. You can also record sound direct in front of the I2S mic!
[edit] @cedric.cfk reported a bad audio quality, sounds similar to my first recordings. I tried to reproduce it by shaking the wires and connectors a bit and it seems to produce this metallic sound:
[edit2] Just FYI, it was actual a connection problem caused by bad cables (jumper wire) on @cedric.cfk’s hardware setup.
For the FiPy you have to use our home brewed firmware with I2S dirver, the official PyCom firmware has this driver not build in! Use at least version FiPy-1.20.1.r1-0.7.0-vanilla-dragonfly-onewire-i2s.tar.gz or better a newer release, see Dragonfly firmware for Pycom/ESP32
After getting a good audio stream out of the INMP441 the next “natural” step would be using this stream for a FFT analysis. Due to performance reasons we should count on this:
The official DSP lib from espressif contains a FFT analysis. But this module is not in our firmware yet.
Can someone guide us a bit more detailed through the process of firmware building and including this module?
@pythoncoder would surely like to know if an FFT costs a king’s ransom. No, it doesn’t. In fact, a 1024-point float transform can be gotten in less than 2 ms on the pyboard.
We are a bit in a dilemma! We have a PyCom firmware (from @Andreas) with an I2S dirver but without FFT support and wie have a firmware with FFT / ulab but without I2S, and we have the official DSP lib which is not integrated in any PyCom firmware yet.
I have asked rcolistete if he has a firmware version with ulab and I2S Pycom firmwares with single/double precision and ulab module | Pycom user forum I pointed him to the pull request from Andreas, hope this is sufficient for a check of feasibility. I feel not so comfortable with this direction becaus I think he has not integrated all the good and helpfull stuff, Andreas hast build in for stability in the last month.
So my favorite would be to integrate the DSP lib (and / or ulab) in Andreas’ firmware code. But as you may know: Busy by other things.
@MKO hat sich das ganze mal angesehen und der Weg könnte sein:
Dragonfly mit ulab pimpen?
Source code zur Dragonfly firmware verwenden (nicht verwirren lassen, der branch heißt squirrel beinhaltet aber den latest and greates dragonfly Stand):
Im Endeffekt brauchen wir, so hoffe ich, nur noch diesen commit:
… und den code zum ulab-Modul hier:
Anleitungen dazu hat @MKO auch gefunden, um daraus wieder eine Firmware zu klöppeln. Wär auf alle Fälle einen Versuch wert.
I2S in die aktuelle firmware mit ulab integrieren?
Noch ein Nachtrag zur Idee das anders rum zu machen, die ulab-PyCom-Firmware mit I2S anzureichern:
ulab hat eine neuere Version als unsere home brewed dragonfly als Grundlage. Hier Pycom · master · Roberto Colistete Junior / MicroPython Firmwares · GitLab schreibt ulab 1.20.2.rc10, Andreas hat als Grundlage 1.20.2.rc6 verwendet. Uns bringt die neueste PyCom firmware aber nichts, wenn die Nachbesserungen von Andreas zu onewire, LTE, core panics … wie hier beschrieben nicht drinnen sind. :-( also bleibt nur der Weg oben.
Habe jetzt mal versucht beide Zweige zu verbinden, was auch geklappt haben müsste, so hoffe ich.
Ich versuche jetzt mit WSL2 die firmware zu Compilen. Zum testen erstmal ohne das ulab Modul.
Allerdings habe ich ein paar Probleme.
Ich bin strikt nach der Anleitung der README.md vorgegangen.
musste allerdings trotzdem den IDF Hasch im Makefile anpassen.
Irgendwas stimmt aber anscheinend mit meinem WSL nicht.
auf xtensa-esp32-elf-gcc wird der Zugriff verweigert.
Hmm, liegt es am aktuellen code oder an der Maschinerie? Du versuchst testweise den den alten Stand von Andreas zu compilieren, ja? Dann dürfte es nicht am neuen code liegen, sondern an der Firmware-Maschine.
