Let’s do some bookkeeping about the different metadata information we will collect and publish.
Rebuild times reflect job scheduling times using cron, stated as respective system time (currently CET in Europe/Berlin).
Metadata about stations and devices
List of stations/devices (locations) from luftdaten.info
Station information metadata from https://luftdaten.info/.
List of DWD stations for 10min measurements
- File: dwd-stations-10min-grafana.json (todo)
List of DWD stations for 60min measurements
- File: dwd-stations-60min-grafana.json (todo)
How to request a resource
There are different ways of requesting a metadata resource. Let’s use the station information metadata from luftdaten.info to demonstrate this by example. All responses should yield the contents of the resource luftdaten-stations-grafana.json
, which is a static file generated by luftdatenpumpe.py
Request variants
GET request
With this GET request, the resource gets addressed by filename. It offers a convenient way to dispatch to metadata resources on the filesystem.
http GET https://weather.hiveeyes.org/metadata/luftdaten-stations-grafana.json
POST request - by filename
With this POST request, the resource gets addressed by filename. It offers a convenient way to dispatch to metadata resources on the filesystem.
echo '{"target": "luftdaten-stations-grafana.json"}' | http POST https://weather.hiveeyes.org/metadata/search
POST request - custom expression
With this POST request, the resource gets addressed by using a custom expression. This offers an advanced way to dispatch to metadata resources on other subsystems.
echo '{"target": "SELECT * FROM luftdaten_stations"}' | http POST https://weather.hiveeyes.org/metadata/search
Under the hood, this query expression is mapped to the static resource "luftdaten-stations-grafana.json"
to reflect it as a database table called "luftdaten_stations"
using a custom rule stored in the variable "ngx.shared.metadata_routes"
