What I am observing is…
root@Calvin:/home/markus/GitHub/terkin-datalogger# make install-ng
Device port: usb => /dev/ttyS3
make[1]: Entering directory '/mnt/c/Users/Markus/Documents/GitHub/terkin-datalogger'
[INFO] Uploading MicroPython code to device using USB
make[1]: Leaving directory '/mnt/c/Users/Markus/Documents/GitHub/terkin-datalogger'
make[2]: Entering directory '/mnt/c/Users/Markus/Documents/GitHub/terkin-datalogger'
.venv3/bin/rshell --port /dev/ttyS3 --user micro --password python --buffer-size 2048 mkdir /flash/dist-packages
Using buffer-size of 2048
Connecting to /dev/ttyS3 (buffer-size 2048)...
Trying to connect to REPL .. connected
Testing if ubinascii.unhexlify exists ... Y
Retrieving root directories ... /boot.py/ /dist-packages/ /lib/ /main.py/ /project.pymakr/ /terkin/ /settings.py/ /backup/
Setting time ... Feb 16, 2020 16:24:06
Evaluating board_name ... pyboard
Retrieving time epoch ... Jan 01, 2000
Unable to create /flash/dist-packages
.venv3/bin/rshell --port /dev/ttyS3 --user micro --password python --buffer-size 2048 rsync dist-packages /flash/dist-packages
Trying to connect to REPL .... connected
Testing if ubinascii.unhexlify exists ... b"ets Jun 8 2016 00:22:57\r\n\r\nrst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)\r\nconfigsip: 0, SPIWP:0xee\r\nclk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00\r\nmode:DIO, clock div:2\r\nload:0x3fff0018,len:4\r\nload:0x3fff001c,len:4844\r\nload:0x40078000,len:10532\r\nload:0x40080400,len:6736\r\nentry 0x400806f0\r\n\x1b[0;32mI (534) psram: This chip is ESP32-D0WD\x1b[0m\r\n\x1b[0;32mI (534) spiram: Found 64MBit SPI RAM device\x1b[0m\r\n\x1b[0;32mI (534) spiram: SPI RAM mode: flash 40m sram 40m\x1b[0m\r\n\x1b[0;32mI (537) spiram: PSRAM initialized, cache is in low/high (2-core) mode.\x1b[0m\r\n\x1b[0;32mI (544) cpu_start: Pro cpu up.\x1b[0m\r\n\x1b[0;32mI (548) cpu_start: Application information:\x1b[0m\r\n\x1b[0;32mI (553) cpu_start: Compile time: Dec 20 2019 07:52:43\x1b[0m\r\n\x1b[0;32mI (559) cpu_start: ELF file SHA256: 0000000000000000...\x1b[0m\r\n\x1b[0;32mI (565) cpu_start: ESP-IDF: v3.3\x1b[0m\r\n\x1b[0;32mI (570) cpu_start: Starting app cpu, entry point is 0x40083d90\x1b[0m\r\n\x1b[0;32mI (562) cpu_start: App cpu up.\x1b[0m\r\n\x1b[0;32mI (1446) spiram: SPI SRAM memory test OK\x1b[0m\r\n\x1b[0;32mI (1446) heap_init: Initializing. RAM available for dynamic allocation:\x1b[0m\r\n\x1b[0;32mI (1446) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM\x1b[0m\r\n\x1b[0;32mI (1452) heap_init: At 3FFBA658 len 000259A8 (150 KiB): DRAM\x1b[0m\r\n\x1b[0;32mI (1459) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM\x1b[0m\r\n\x1b[0;32mI (1465) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM\x1b[0m\r\n\x1b[0;32mI (1472) heap_init: At 400973F0 len 00008C10 (35 KiB): IRAM\x1b[0m\r\n\x1b[0;32mI (1478) cpu_start: Pro cpu start user code\x1b[0m\r\n\x1b[0;32mI (154) cpu_start: Chip Revision: 1\x1b[0m\r\n\x1b[0;33mW (155) cpu_start: Chip revision is higher than the one configured in menuconfig. Suggest to upgrade it.\x1b[0m\r\n\x1b[0;32mI (158) cpu_start: Starting scheduler on PRO CPU.\x1b[0m\r\n\x1b[0;32mI (0) cpu_start: Starting scheduler on APP CPU.\x1b[0m\r\n[boot.py] INFO: Python module search path is: ['', '/lib']\r\n[boot.py] INFO: Universal MicroPython Application Loader (umal)\r\n[umal] INFO: Python module search path is: ['/lib-mpy-1.11-bytecode', '', '/lib', '/dist-packages', '/terkin']\r\n[main.py] INFO: Loading settings\r\n[main.py] INFO: Starting logging\r\n[main.py] INFO: Loading Terkin Datalogger\r\n[main.py] INFO: Loading modules\r\n"
File "/mnt/c/Users/Markus/Documents/GitHub/terkin-datalogger/.venv3/lib/python3.7/site-packages/rshell/main.py", line 1255, in connect
ip_address = socket.gethostbyname(port)
socket.gaierror: [Errno -2] Name or service not known
During handling of the above exception, another exception occurred:
File ".venv3/bin/rshell", line 8, in <module>
sys.exit(main())
File "/mnt/c/Users/Markus/Documents/GitHub/terkin-datalogger/.venv3/lib/python3.7/site-packages/rshell/command_line.py", line 4, in main
rshell.main.main()
File "/mnt/c/Users/Markus/Documents/GitHub/terkin-datalogger/.venv3/lib/python3.7/site-packages/rshell/main.py", line 2843, in main
real_main()
File "/mnt/c/Users/Markus/Documents/GitHub/terkin-datalogger/.venv3/lib/python3.7/site-packages/rshell/main.py", line 2805, in real_main
connect(args.port, baud=args.baud, wait=args.wait, user=args.user, password=args.password)
File "/mnt/c/Users/Markus/Documents/GitHub/terkin-datalogger/.venv3/lib/python3.7/site-packages/rshell/main.py", line 1261, in connect
connect_serial(port, baud=baud, wait=wait)
File "/mnt/c/Users/Markus/Documents/GitHub/terkin-datalogger/.venv3/lib/python3.7/site-packages/rshell/main.py", line 1285, in connect_serial
dev = DeviceSerial(port, baud, wait)
File "/mnt/c/Users/Markus/Documents/GitHub/terkin-datalogger/.venv3/lib/python3.7/site-packages/rshell/main.py", line 1565, in __init__
Device.__init__(self, pyb)
File "/mnt/c/Users/Markus/Documents/GitHub/terkin-datalogger/.venv3/lib/python3.7/site-packages/rshell/main.py", line 1339, in __init__
unhexlify_exists = self.remote_eval(test_unhexlify)
File "/mnt/c/Users/Markus/Documents/GitHub/terkin-datalogger/.venv3/lib/python3.7/site-packages/rshell/main.py", line 1459, in remote_eval
return eval(self.remote(func, *args, **kwargs))
File "/mnt/c/Users/Markus/Documents/GitHub/terkin-datalogger/.venv3/lib/python3.7/site-packages/rshell/main.py", line 1437, in remote
self.pyb.enter_raw_repl()
File "/mnt/c/Users/Markus/Documents/GitHub/terkin-datalogger/.venv3/lib/python3.7/site-packages/rshell/pyboard.py", line 187, in enter_raw_repl
raise PyboardError('could not enter raw repl')
rshell.pyboard.PyboardError: could not enter raw repl
make[2]: *** [Makefile:240: install-requirements] Error 1
make[2]: Leaving directory '/mnt/c/Users/Markus/Documents/GitHub/terkin-datalogger'
make[1]: *** [Makefile:217: install-rshell] Error 2
make: *** [Makefile:227: install-ng] Error 2
