Arduino MKRFOX1200
  • Atmel SAM D21: ARM Cortex M0+ MCU
  • Atmel ATA8520: SigFox module
Description
Arduino MKRFOX1200 has been designed to offer a practical and cost effective solution for makers seeking to add SigFox connectivity to their projects with minimal previous experience in networking. It is based on the Atmel SAMD21 and a ATA8520 SigFox module.
The design includes the ability to power the board using two 1.5V AA or AAA batteries or external 5V. Switching from one source to the other is done automatically. A good 32 bit computational power similar to the Zero board, the usual rich set of I/O interfaces, low power SigFox communication and the ease of use of the Arduino Software (IDE) for code development and programming.
All these features make this board the preferred choice for the emerging IoT battery-powered projects in a compact form factor. The USB port can be used to supply power (5V) to the board. The Arduino MKRFOX1200 is able to run with or without the batteries connected and has limited power consumption.
Links
Specifications
Microcontroller	                SAMD21 Cortex-M0+ 32bit low power ARM MCU
Board Power Supply (USB/VIN)	5V
Supported Batteries(*)	        2x AA or AAA
Circuit Operating Voltage   	3.3V
Digital I/O Pins               	8
PWM Pins	                    12 (0, 1, 2, 3, 4, 5, 6, 7, 8, 10, A3 - or 18 -, A4 -or 19)
UART	                        1
SPI	                            1
I2C	                            1
Analog Input Pins	            7 (ADC 8/10/12 bit)
Analog Output Pins	            1 (DAC 10 bit)
External Interrupts	            8 (0, 1, 4, 5, 6, 7, 8, A1 -or 16-, A2 - or 17)
DC Current per I/O Pin	        7 mA
Flash Memory	                256 KB
SRAM	                        32 KB
EEPROM	                        no
Clock Speed	                    32.768 kHz (RTC), 48 MHz
LED_BUILTIN	                    6
Full-Speed USB Device and embedded Host
LED_BUILTIN	                    6
Antenna power	                2dB
Carrier frequency	            868 MHz
Working region	                EU
Length	                        67.64 mm
Width	                        25 mm
Weight	                        32 gr.
Source: Arduino MKR FOX 1200
Habe jetzt hier nur Daten vom MKR1000, aber der Stromverbrauch schaut recht hoch aus
Wie weit man den drosseln und batterie-tauglich machen kann habe ich noch nicht herausgefunden. .
Spannend ist der MKR mit dem Cortex-M0 aber auch aus einem anderen Grund:
  • er kann I2S !
  • es gibt eine lib, die mit dem I2S-Input auch Spektrum-Analyse kann!
Statt des MKRxx bietet sich auch ein Feather M0 mit LoRa-Module (RFM95) an:
Den konnte ich z.B schon dazu bewegen über die RadioHead-Lib mit einem LoPy als potentielles gateway zu WiFi zu reden.
Hier gibt es ein Tutorial und Beispiele zur Spektrum-Analyse:
Und hier die offizielle Seite zur ArduinoSound Library:
https://www.arduino.cc/en/Reference/ArduinoSound
Nun noch ein Nachtrag zur SigFox-Version des MKR (“MKR” soll übrigens für MaKeR stehen :-): Heise schreibt, dass die ersten zwei Jahre Datenübertragung inklusive seien, allerdings mit der üblichen Beschränkung bei SigFox mit 140 Nachrichten pro Tag (upstream, also vom node zum gateway) und dem Hinweis zur ggf. mangelnden geografischen Abdeckung:
Auch der SODAQ Autonomo hat den ARM Cortex M0 und sollte das können. Ist für uns interessant, da er ähnlich wie der Seeeduino Stalker auch einen charging chip für LiPo via Solarzelle hat, eine RTC (allerdings anders angesprochen als beim Stalker) und ein beeSocket für ein GSM-Modul. Allerdings nochmal teurer als der Stalker.
Zum Thema low power und Batterie:
Das ist zwar für den MKR WAN1300, ich denke aber die Sigfox-MKR-Version und andere Module haben ähnliche Probleme, da sie nicht by design für low power ausgelegt sind, aber immerhin wird das ggf. für die nächste Interation versprochen.
