Ok, schaut schon mal anders aus:
>>> ets Jun 8 2016 00:22:57
rst:0x1 (POWERON_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
mode:DIO, clock div:2
load:0x3fff0018,len:4
load:0x3fff001c,len:4844
load:0x40078000,len:10532
load:0x40080400,len:6736
entry 0x400806f0
I (525) psram: This chip is ESP32-D0WD
I (525) spiram: Found 64MBit SPI RAM device
I (525) spiram: SPI RAM mode: flash 40m sram 40m
I (528) spiram: PSRAM initialized, cache is in low/high (2-core) mode.
I (535) cpu_start: Pro cpu up.
I (539) cpu_start: Application information:
I (544) cpu_start: Compile time: Dec 20 2019 07:52:43
I (550) cpu_start: ELF file SHA256: 0000000000000000...
I (556) cpu_start: ESP-IDF: v3.3
I (561) cpu_start: Starting app cpu, entry point is 0x40083d90
I (0) cpu_start: App cpu up.
I (1436) spiram: SPI SRAM memory test OK
I (1437) heap_init: Initializing. RAM available for dynamic allocation:
I (1437) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM
I (1443) heap_init: At 3FFBA658 len 000259A8 (150 KiB): DRAM
I (1450) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM
I (1456) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
I (1463) heap_init: At 400973F0 len 00008C10 (35 KiB): IRAM
I (1469) cpu_start: Pro cpu start user code
I (145) cpu_start: Chip Revision: 1
W (146) cpu_start: Chip revision is higher than the one configured in menuconfig. Suggest to upgrade it.
I (149) cpu_start: Starting scheduler on PRO CPU.
I (0) cpu_start: Starting scheduler on APP CPU.
[boot.py] INFO: Python module search path is: ['', '/lib']
[boot.py] INFO: Universal MicroPython Application Loader (umal)
[umal] INFO: Python module search path is: ['/lib-mpy-1.11-bytecode', '', '/lib', '/dist-packages', '/terkin']
[main.py] INFO: Loading Terkin Datalogger
I (18560) modsocket: Initializing
22.9520 [terkin.datalogger ] INFO : Starting Terkin datalogger
23.1770 [terkin.configuration ] INFO : Starting TerkinConfiguration on path "/"
23.4000 [terkin.configuration ] INFO : Ensuring existence of backup directory at "/backup"
23.6970 [terkin.configuration ] INFO : User settings: None
24.3420 [terkin.device ] INFO : Reset cause and wakeup reason: {'reset_cause': {'code': 1, 'message': 'PWRON'}, 'wakeup_reason': {'code': 0, 'message': 'UNKNOWN'}}
24.5690 [terkin.watchdog ] INFO : Skipping watchdog timer (WDT)
24.7900 [terkin.device ] INFO : Start curating the garbage collector
25.2120 [terkin.device ] INFO : Collecting garbage
25.6710 [terkin.device ] INFO : Curating the garbage collector finished. Free memory: 3912816
25.8930 [terkin.device ] WARNING: FIXME: Skip touching Bluetooth on vanilla MicroPython platforms as we don't use Bluetooth yet
26.1200 [terkin.datalogger ] INFO : Starting Terkin MicroPython Datalogger 0.6.0
26.3510 [terkin.configuration ] INFO : Configuration settings:
26.6050 [terkin.configuration ] INFO : Section "telemetry": {"targets": [{"enabled": false, "topology": "mqttkit", "endpoint": "mqtt://swarm.hiveeyes.org", "address": {"network": "testdrive", "gateway": "area-42", "node": "node-01-mqtt-json", "realm": "workbench"}}, {"enabled": false, "topology": "mqttkit", "endpoint": "https://daq.example.org/api", "address": {"network": "testdrive", "gateway": "area-42", "node": "node-01-http-json", "realm": "workbench"}}, {"topology": "mqttkit", "interface": "gprs", "address": {"network": "testdrive", "gateway": "area-005", "node": "t-call-cg-01", "realm": "hiveeyes"}, "enabled": true, "endpoint": "https://swarm.hiveeyes.org/api"}, {"enabled": false, "data": {"key": "## redacted ##"}, "endpoint": "https://test.free.beeceptor.com/api/sensors"}, {"format": "lpp", "content_encoding": "base64", "address": {"network": "testdrive", "gateway": "area-42", "node": "node-01-mqtt-lpp", "realm": "workbench"}, "enabled": false, "endpoint": "mqtt://daq.example.org"}, {"enabled": true, "settings": {"size": 12, "datarate": 0}, "endpoint": "lora://", "format": "lpp"}]}
26.9250 [terkin.configuration ] INFO : Section "interfaces": {"uart0": {"terminal": false}}
27.1610 [terkin.configuration ] INFO : Section "main": {"interval": {"maintenance": 15.0, "field": 60.0}, "logging": {"enabled": true, "configuration": true}, "rgb_led": {"terkin": false, "heartbeat": true}, "deepsleep": false, "watchdog": {"enabled": false, "timeout": 60000}, "backup": {"file_count": 7}}
27.4200 [terkin.configuration ] INFO : Section "networking": {"wifi": {"stations": [{"ssid": "FooBar", "password": "## redacted ##"}], "enabled": false, "phy": {"antenna_external": false, "antenna_pin": "P12"}}, "lora": {"enabled": false, "otaa": {"adr": false, "region": "EU868", "application_key": "## redacted ##", "application_eui": "## redacted ##", "device_eui": "<GENERATED_FROM_LORA_MAC>"}, "antenna_attached": false}, "gprs": {"pin_reset": "P5", "enabled": true, "apn": "internet.telekom", "pin_power": "P23", "driver": "pythings-sim800", "pin_txd": "P26", "pin_rxd": "P27", "pin_pwrkey": "P4"}}
27.7380 [terkin.configuration ] INFO : Section "sensors": {"system": [{"type": "system.memfree"}, {"type": "system.temperature"}, {"type": "system.uptime"}, {"type": "system.wifi"}, {"enabled": false, "type": "system.touch-buttons"}, {"enabled": true, "resistor_r2": 1000, "pin": "P16", "description": "Battery", "type": "system.voltage.battery", "resistor_r1": 1000, "adc_attenuation_db": 6.0}, {"enabled": false, "resistor_r2": 100, "pin": "P17", "description": "Solar Panel", "type": "system.voltage.solar", "resistor_r1": 1000, "adc_attenuation_db": 11.0}], "environment": [{"pin_dout": "P22", "scale": 4.424242, "offset": -73000, "enabled": true, "name": "scale", "description": "Waage 1", "id": "scale-1", "number": 0, "pin_pdsck": "P21", "type": "HX711"}, {"enabled": true, "bus": "onewire:0", "name": "temperature", "description": "Wabengasse 1", "id": "ds18b20-1", "type": "DS18B20", "devices": [{"id": "ds18b20-r1c1", "enabled": true, "address": "1111111111111111", "description": "Reihe 1, Spalte 1"}, {"id": "ds18b20-r1c2", "enabled": true, "address": "2222222222222222", "description": "Reihe 1, Spalte 2"}]}, {"id": "bme280-1", "description": "Temperatur und Feuchte außen", "type": "BME280", "address": 119, "enabled": true, "bus": "i2c:0"}], "busses": [{"id": "bus-i2c-0", "family": "i2c", "number": 0, "pin_sda": "P9", "enabled": true, "pin_scl": "P10"}, {"id": "bus-i2c-1", "family": "i2c", "number": 1, "pin_sda": "P22", "enabled": false, "pin_scl": "P21"}, {"enabled": true, "family": "onewire", "pin_data": "P11", "id": "bus-onewire-0", "number": 0}], "prettify_log": true}
28.1080 [terkin.configuration ] INFO : Section "services": {"api": {"modeserver": {"enabled": false}, "http": {"enabled": false}}}
28.6070 [terkin.device ] INFO :
Device id 30aea4c28138
CPU freq 160.0 MHz
Python : 3.4.0
machine : ESP32 module (spiram) with ESP32
nodename: esp32
release : 1.12.0
sysname : esp32
version : v1.12 on 2019-12-20
28.8500 [terkin.device ] INFO : Starting networking
29.0910 [terkin.network.wifi ] INFO : Starting stopwatch
29.7280 [terkin.network.wifi ] INFO : Started stopwatch successfully
29.9590 [terkin.device ] INFO : [WiFi] interface disabled in settings.
30.1800 [terkin.device ] INFO : [LoRa] This is not a LoRa capable device.
I (37320) uart: ALREADY NULL
46.2050 [terkin.device ] INFO : Starting telemetry
46.4420 [terkin.telemetry ] INFO : Telemetry channel topology: MqttKitTopology
46.6790 [terkin.telemetry ] INFO : Telemetry channel URI: https://swarm.hiveeyes.org/api/hiveeyes/testdrive/area-005/t-call-cg-01
46.9030 [terkin.telemetry ] INFO : Starting Terkin TelemetryClient
47.1420 [terkin.telemetry ] INFO : Telemetry channel topology: IdentityTopology
47.3680 [terkin.telemetry ] INFO : Telemetry channel URI: lora://
47.5910 [terkin.telemetry ] INFO : Starting Terkin TelemetryClient
47.8420 [terkin.sensor.core ] INFO : Starting all busses [{'enabled': True, 'family': 'i2c', 'pin_scl': 'P10', 'pin_sda': 'P9', 'id': 'bus-i2c-0', 'number': 0}, {'enabled': False, 'family': 'i2c', 'pin_scl': 'P21', 'pin_sda': 'P22', 'id': 'bus-i2c-1', 'number': 1}, {'pin_data': 'P11', 'id': 'bus-onewire-0', 'number': 0, 'family': 'onewire', 'enabled': True}]
Guru Meditation Error: Core 1 panic'ed (LoadProhibited). Exception was unhandled.
Core 1 register dump:
PC : 0x400d3730 PS : 0x00060730 A0 : 0x800e111e A1 : 0x3ffc1c30
A2 : 0x00000725 A3 : 0x3ff53000 A4 : 0x3ffb0094 A5 : 0x00000120
A6 : 0x00000000 A7 : 0x3ffc4368 A8 : 0x800d3730 A9 : 0x3ffc1c10
A10 : 0xffffffff A11 : 0x400828c8 A12 : 0x3ffc4368 A13 : 0x00000000
A14 : 0x3ffc4370 A15 : 0x00000001 SAR : 0x00000014 EXCCAUSE: 0x0000001c
EXCVADDR: 0x00000000 LBEG : 0x40096d7c LEND : 0x40096d87 LCOUNT : 0xffffffff
ELF file SHA256: 0000000000000000000000000000000000000000000000000000000000000000
Backtrace: 0x400d3730:0x3ffc1c30 0x400e111b:0x3ffc1c50 0x400e8f36:0x3ffc1c80 0x400e953a:0x3ffc1ca0 0x400dfd19:0x3ffc1d00 0x400ed216:0x3ffc1d30 0x400e3e68:0x3ffc1dd0 0x400dfaa1:0x3ffc1e00 0x400dfb09:0x3ffc1e20 0x400edc45:0x3ffc1e40 0x400e3e68:0x3ffc1ee0 0x400dfaa1:0x3ffc1f60 0x400dfb09:0x3ffc1f80 0x400edc45:0x3ffc1fa0 0x400e3e68:0x3ffc2040 0x400dfaa1:0x3ffc2070 0x400dfb09:0x3ffc2090 0x400edc45:0x3ffc20b0 0x400e3e68:0x3ffc2150 0x400dfaa1:0x3ffc2180 0x400dfb09:0x3ffc21a0 0x400edc45:0x3ffc21c0 0x400e3e68:0x3ffc2260 0x400dfaa1:0x3ffc22e0 0x400edbb9:0x3ffc2300 0x400e3e68:0x3ffc23a0 0x400dfaa1:0x3ffc2400 0x400dface:0x3ffc2420 0x40104b58:0x3ffc2440 0x40104dcd:0x3ffc24e0 0x40104e2b:0x3ffc2500 0x400f5ad5:0x3ffc2520 0x40092d59:0x3ffc2550
Rebooting...
rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
entry 0x400806f0
E (526) spiram: SPI RAM enabled but initialization failed. Bailing out.
I (526) cpu_start: Failed to init external RAM; continuing without it.
I (533) cpu_start: Pro cpu up.
I (537) cpu_start: Application information:
I (542) cpu_start: Compile time: Dec 20 2019 07:52:43
I (548) cpu_start: ELF file SHA256: 0000000000000000...
I (554) cpu_start: ESP-IDF: v3.3
I (558) cpu_start: Starting app cpu, entry point is 0x40083d90
I (550) cpu_start: App cpu up.
I (569) heap_init: Initializing. RAM available for dynamic allocation:
I (576) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM
I (582) heap_init: At 3FFBA658 len 000259A8 (150 KiB): DRAM
I (588) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM
I (594) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
I (601) heap_init: At 400973F0 len 00008C10 (35 KiB): IRAM
I (607) cpu_start: Pro cpu start user code
I (290) cpu_start: Chip Revision: 1
W (291) cpu_start: Chip revision is higher than the one configured in menuconfig. Suggest to upgrade it.
I (294) cpu_start: Starting scheduler on PRO CPU.
E (40) spiram: SPI RAM not initialized
File "main.py", line 59, in <module>
File "main.py", line 37, in main
File "/lib/terkin/datalogger.py", line 14, in <module>
File "/lib/terkin/device.py", line 13, in <module>
MemoryError: memory allocation failed, allocating 578 bytes
MicroPython v1.12 on 2019-12-20; ESP32 module (spiram) with ESP32
