Dragino LA66 LoRaWAN USB
The LA66 USB LoRaWAN Adapter is designed to fast turn USB devices to support LoRaWAN wireless features. It combines a CP2101 USB TTL Chip and LA66 LoRaWAN module which can easy to add LoRaWAN wireless feature to PC / Mobile phone or an embedded device that has USB Interface.
Description
  • LA66 is a ready-to-use module that includes LoRaWAN v1.0.3 protocol. External MCU can use AT command to call LA66 and start to transmit data via the LoRaWAN protocol.
  • Each LA66 module includes a world-unique OTAA key for LoRaWAN registration.
  • Besides the support of the LoRaWAN protocol, LA66 also supports open-source peer-to-peer LoRa Protocol for the none-LoRaWAN application.
  • LA66 is equipped with TCXO crystal which ensures the module can achieve stable performance in extreme temperatures.
Features
  • LoRaWAN USB adapter base on LA66 LoRaWAN module
  • Ultra-long RF range
  • Support LoRaWAN v1.0.3 protocol
  • Support peer-to-peer protocol
  • TCXO crystal to ensure RF performance on low temperature
  • Spring RF antenna
  • Available in different frequency LoRaWAN frequency bands.
  • World-wide unique OTAA keys.
  • AT Command via UART-TTL interface
  • Firmware upgradable via UART interface
  • Open Source Mobile App for LoRaWAN signal detect and GPS tracking.
Specifications
  • CPU: ASR6601 SoC (32-bit 48 MHz)
  • Flash: 256KB
  • RAM: 64KB
  • Input Power Range: 5v
  • Frequency Range: 150 MHz ~ 960 MHz
  • Maximum Power +22 dBm constant RF output
  • High sensitivity: -148 dBm
  • Temperature:
    • Storage: -55 ~ +125℃
    • Operating: -40 ~ +85℃
  • Humidity:
    • Storage: 5 ~ 95% (Non-Condensing)
    • Operating: 10 ~ 95% (Non-Condensing)
  • LoRa Tx Current: <90 mA at +17 dBm, 108 mA at +22 dBm
  • LoRa Rx current: <9 mA
Resources
