It actually should work. The error looks like it is coming from not having the osbh-audioanalyzer binary available at the given path “tools/osbh-audioanalyzer/bin/test
”. We also improved the error handling and reporting per commit 33cff044, so you might want to check again with the updated version by issuing “git pull
” before trying again. Thanks!
Noch eine kleine Frage: Wo finde ich denn die Grafiken zur Leistungsdichte, falls sie trotz des matplotlib-Fehlers generiert werden können?
Man gibt bei den entsprechenden subcommands (z.B. “audiohealth power
”) die Ausgabedatei an. Siehe “audiohealth --help
”. Dafür musst Du audiohealth per “xvfb-run audiohealth power ...
” aufrufen, hier kommt also “xvfb-run” zum Einsatz, wenn Du das Teil “headless” betreiben willst.
Danke fürs Nachfragen, diese Information ist bisher noch nicht in der README zu finden.
I got still some erroes:
pi@raspberrypi:~/audiohealth $ audiohealth analyze --audiofile ~/bee-sound/hive11_queen-nucleus-some-weeks-old_2017-07-21_12-52-10.mp3 --strategy lr-2.0 --analyzer tools/osbh-audioanalyzer/bin/test
Unable to init server: Could not connect: Connection refused
(audiohealth:1586): Gdk-CRITICAL **: gdk_cursor_new_for_display: assertion 'GDK_IS_DISPLAY (display)' failed
WARNING: matplotlib not available. Will not be able to generate funny pictures.
Duration: 50s
File: /tmp/tmpFL0FGF.wav.dat
Strategy: lr-2.0
Sequence of states
swarm, swarm, collapsed, swarm, collapsed
Don’t care about these warnings and errors when running the “analyze” part of the “audiohealth” program. However, when trying to generate spectrogram and power-spectrum images, prefixing the command with “xvfb-run audiohealth...
” might help for running the program in “headless” mode.
There might be other reasons, but i haven’t seen this error yet. But as others did already, you might find these hints useful and we would be happy about any feedback:
Hi Andreas,
I’d like to analyse .wav files from my beehives and have cloned and uploaded audiohealth 0.4.0 from github to my raspberry pi.
Would you be able to tell me if:
- there is a new version that I could clone? (current in github is 0.4.0 2017)
- Am I doing something wrong? Setup, permissions, error in command lines.
- do I need to do some pre editting to the samples ie (40sec samples, only bee sounds, no background noise)
Kind regards Paul
Raspberry Pi 3 Screen:
(.venv27) pi@raspberrypi:~/audiohealth $ audiohealth power --wavfile samples/CF003AD000.wav --pngfile samples/CF003AD000.png
Peaks by frequency
86.13 Hz 130.14 RMS
Peaks by power
130.14 RMS 86.13 Hz
Analysis
File "/home/pi/audiohealth/.venv27/bin/audiohealth", line 11, in <module>
load_entry_point('audiohealth', 'console_scripts', 'audiohealth')()
File "/home/pi/audiohealth/audiohealth.py", line 488, in main
tmpfile = power_spectrum(wavfile)
File "/home/pi/audiohealth/audiohealth.py", line 398, in power_spectrum
freq500 = max(band500, key=peak_data.get)
ValueError: max() arg is an empty sequence
(.venv27) pi@raspberrypi:~/audiohealth $ audiohealth --version
audiohealth 0.4.0
@Flat we as hiveeyes built the audiohealth framework based on an audio categorization algorithm from OSBH years ago. In this day OSBH published the relevant code as open source! Unfortunately the business model / mindset changed and OSBH did not release new code and optimized detection algorithms as open source, see:
Afaik OSBH published only the categorization alog and never the learning code. So we had no chance to go on without developing a big part of software new. Unfortunately we had to stopp developing because we have – with the current code – no chance to optimize the detection algorithem. So we gave up eo 2017.
@clemens: Thank you for the reply.
I guess the world of AI has changed since 2017 and no longer the cloistered retreat of the few very smart people. Hopefully it has become more mainstream as we move toward simpler AI tools accessible through Google, Azure and AWS.
I did manage to get some results from the legacy OSBH categorization tool. It made a nice learning experience for me to try out. I had some success running two commands with the file that failed in my previous comment.
1. Analyse
(.venv27) pi@raspberrypi:~/audiohealth $ audiohealth analyze --wavfile samples/CF003AD000.wav --analyzer tools/osbh-audioanalyzer/bin/test
Duration: 39s
File: samples/CF003AD000.wav.dat
Strategy: lr-2.1
Sequence of states
swarm, active, active, active, active, active, active, active, active, active, active, active, active, active, active, active, active, active, active, active, active, active, active, active, active, active, active
Compressed timeline
0s - 10s swarm =
10s - 270s active ==========================
Total duration
260s active ==========================
10s swarm =
Result
The most common events (i.e. the events with the highest total duration) are:
The colony is mostly in »ACTIVE« state, which is going on for 260 seconds.
Sometimes, the state oscillates to »SWARM«, for 10 seconds in total.
Disclaimer
THERE IS NO WARRANTY FOR THE PROGRAM, TO THE EXTENT PERMITTED BY APPLICABLE LAW. NO LIABILITY FOR ANY DAMAGES WHATSOEVER.
2. Spectrogram
(.venv27) pi@raspberrypi:~/audiohealth $ audiohealth spectrogram --audiofile samples/CF003AD000.wav --pngfile samples/CF003AD000spec.png
total time: 39.90s, samplerate: 44.10kHz
A nice spectrogram image was created in file location: audiohealth/samples/CF003AD000spec.png
The Spectrogram function works with my .wav files but not .mp3.
A big thank you to all those engineers who built this for the beekeeping community to try out world wide.
Hi Paul,
thank you for sharing your observations when using the audiohealth
program. As @clemens mentioned, we did not actively follow the development past the initial spike we conceived in 2017.
The code you will find in the repository is the most recent one we have. However, after tag 0.4.0, some more commits have been added. But I assume you cloned the repository and run the most recent version anyway?
I believe you followed all instructions correctly.
I am sorry that I can’t answer that question. Maybe @clemens has some additional thoughts here?
I believe we should get the code up to speed, add support for Python 3 and drop support for Python 2, which is way past end-of-life already. For that purpose, I just created a note at Add support for Python 3 · Issue #3 · hiveeyes/audiohealth · GitHub.
That would be another option (feature) to consider. In order to track it, I just created Add support for analyzing MP3 files · Issue #2 · hiveeyes/audiohealth · GitHub.
Please let us know if we missed to answer any of your questions or how we can support you further. If your journey will yield any better outcome than what we have right now, we will be all ears!
Without looking,i think that the Spectrogram functions comes from Sox.
Have you try to install the .mp3 lib for SOX?
sudo apt-get install libsox-fmt-mp3
or
sudo apt-get install libsox-fmt-all
That sould be install all sound libs for Sox.
I’m thrilled that the code still works so far.
Because I myself will try to immerse myself in the world of audio analysis.
The first steps I have taken so far are. A permanent audio recording to be made with the help of saraswati.To generate data sets for machine learning.
- developing-saraswati-a-robust-multi-channel-audio-recording-transmission-and-storage-system
- Erschliessung-von-saraswati-fur-den-betrieb-auf-einem-industrie-pc-mit-upload-per-ssh-rsync-auf-synology-nas
- installation-von-saraswati-auf-sbc-systemen-debian-mit-upload-per-rsync-oder-ftp
Unfortunately mostly in German. Don’t be afraid to use the translation function and answer in english.
The project is maturing slowly but surely.
I would look forward to test files and cooperation in any case.
But since I don’t want any audio loss for a possible alogerism, i save my data in .flac format.
Michael.
I think the algorithm is not very robust. I would expect that a Bach prelude would lead to a “valid” output like swarm
or active
also and there is no error detection for “wrong” sounds. So it is always a good idea to trim files so that you do not have non-bee sound.
But let me emphasize this again: Detecting backround noise or other not bee based sound would be the job for an good algorithm. And even the output for bee sound I have seen 2017 was very fragile, see Analyze recordings from queen vs. queenless hives using "audiohealth" So I would not count on the ouput at all beside an experimental interest on the program.
MP3 files are optimized for humans, for speach, for music. The secret behind the MP3 technology is that “not important” sound elements are erased, reduced. So the original sound is modified! We (or I :-) do not know how different bee sound is compared to human sound. So it could be that important information in the be sound is deleted by the MP3 algorithm.
In the current state – we do not know what frequencies are important as information source – I would not use any lossy compression. Perhaps this may change in the future or you say it’s not practically doable without heavy compression but it is an imformation loss and we do not know if this information is important. Saying this with less than Wikipedia-knowledge about MP3 compression. So feel free to add more substantial information. ;-)
@Andreas Your insight is much appreciated. Thankyou for your responses.
@MKO libsox-fmt-all is installed at the setup stage. Running the command again confirms the latest version and declares no updates required. Thanks for the ideas.
@clemens My hive installation generates (40sec) .wav files/min from the colony approx 120Mb and delivers them via wifi or 4G to my Raspberry Pi.
I notice using the results from the .wavfile function are not the same as the .audiofile function using the same sample file (PCM004.WAV)
(.venv27) pi@raspberrypi:~/audiohealth $ audiohealth analyze --audiofile samples/PCM004.WAV --analyzer tools/osbh-audioanalyzer/bin/test
Duration: 30s
File: /tmp/tmpvRUkoK.wav.dat
Strategy: lr-2.1
Sequence of states
missing_queen, missing_queen, missing_queen
Compressed timeline
0s - 30s missing_queen ===
Total duration
Result
The colony is mostly in »MISSING_QUEEN« state, which is going on for 30 seconds.
Disclaimer
(.venv27) pi@raspberrypi:~/audiohealth $ audiohealth analyze --wavfile samples/PCM004.WAV --analyzer tools/osbh-audioanalyzer/bin/test
Duration: 30s
File: samples/PCM004.WAV.dat
Strategy: lr-2.1
Sequence of states
Compressed timeline
0s - 230s active =======================
Total duration
Result
The colony is mostly in »ACTIVE« state, which is going on for 230 seconds.
Disclaimer
Hi Paul,
thanks for your report.
Is there any way you could share this file with us?
wget -O PCM004.WAV \
https://community.hiveeyes.org/uploads/default/original/2X/7/7595f1ad65c69e20c87dcb324f5d049080315aef.wav
Dear Paul,
I believe we should get the code up to speed, add support for Python 3 and drop support for Python 2.
I just pushed some updates to the repository. Please make sure to follow the slightly updated setup instructions at GitHub - hiveeyes/audiohealth: Bee colony vitality using audio analysis. Applies machine learning algorithms in C++ from the OSBH project..
$ audiohealth power [...] ValueError: max() arg is an empty sequence
"audiohealth power"
now should work again. I am not sure about "audiohealth spectrogram"
though.
I notice using the results from the .wavfile function are not the same as the .audiofile function.
I haven’t been able to find time to look into this. Apologies.
Unfortunately, on the audio file you provided, I can’t find the appropriate URL to download the file to my machine. It looks like Discourse does not reveal the original URL any more when uploading artefacts.
Hi Andreas,
I dont have a URL for the file, its a simple .wav file from a Digitech XC-0389. To access the uploaded audio file. Is it possible to hover your the cursor over the uploaded audio file in chat, right click. “Save audio as” then you will have the audio file loaded to your computer.
Kind regards Paul
or just click the 3 vertical dots next to the file in chat
Hi Paul,
Indeed I haven’t been aware of that, thanks a stack!
P.S.: Right when you added your answer, I also have been able to find out about this detail (but also more regarding how Discourse encodes file upload identifiers) by asking at https://meta.discourse.org/t/decoding-upload-identifier-to-url/200117.
I can confirm errors with the files both of you provided, when invoking "audiohealth power ..."
. Thanks again. For tracking this error, I just created https://github.com/hiveeyes/audiohealth/issues/5.
$ audiohealth analyze --audiofile samples/PCM004.WAV --analyzer tools/osbh-audioanalyzer/bin/test [...] ================== Sequence of states ================== missing_queen, missing_queen, missing_queen
For me, when using the file PCM004.WAV
$ audiohealth analyze --audiofile=PCM004.WAV --analyzer=tools/osbh-audioanalyzer/bin/test
this outputs:
Duration: 30.976031746031747s
File: /var/folders/06/w9pzygdj7vx53n_0l9q_lhph0000gn/T/tmph5kac3uw.wav.dat
Strategy: lr-2.1
Sequence of states
swarm, swarm, swarm, swarm, swarm, swarm
Compressed timeline
0s - 60s swarm ======
Total duration
60s swarm ======
Result
The colony is mostly in »SWARM« state, which is going on for 60 seconds.
