– Update Pycom WiPy Firmware From Commandline
@hedleyd Not sure if this helps, but the WiPy 2.0 is a tarball which contains
bootloader.bin
,partition.bin
and the firmware itselfwipy.bin
. Bootloader goes to0x1000
, partition table to0x8000
and firmware to0x10000
. Ie to flash everything one could:$ esptool.py --port /dev/cu.usbserial* --baud 115200 --after no_reset write_flash --flash_mode dio --flash_freq 80m --flash_size detect 0x1000 bootloader.bin $ esptool.py --port /dev/cu.usbserial* --baud 115200 --after no_reset write_flash --flash_mode dio --flash_freq 80m --flash_size detect 0x8000 partitions.bin $ esptool.py --port /dev/cu.usbserial* --baud 115200 --after no_reset write_flash --flash_mode dio --flash_freq 80m --flash_size detect 0x10000 wipy.bin
More thorough instructions in this blog post.
– Telnet to esp32 · Issue #191 · micropython/micropython-esp32 · GitHub
