back on the map :) after beeing offline a couple of years the plan is to get the very same setup ( hiveeyes/kh/cfb/hive1) online again this year… hello again!
Good plan. But, don’t you want to publish to a different channel, because, well, it’s probably a different hive now? You can easily adjust the later two path components, cfb, and hive1, to suit your needs, and to create arbitrary (numbers of) channels.
