Thias
December 16, 2019, 9:11am
1
system.temperature always returns implausible values, like
Log:
system.temperature 12.6087
and Dashboard . The peaks in system.temperature are from times when I developed with the board.
Shouldn’t machine.temparature()
return values in Fahrenheit and where is this formula from?
'not implemented on this platform')
rawvalue = machine.temperature()
# Fahrenheit
# 'system.temperature': 57.77778
#temperature = (rawvalue - 32) / 1.8
# Magic
# 'system.temperature': 41.30435
value = rawvalue * (44/23) + (-5034/23)
reading = {'system.temperature': value}
return reading
class SystemBatteryLevel(AbstractSystemSensor):
Read the battery level by sampling the ADC on a pin connected
to a voltage divider. As the Pycom expansion board is using
Pin 16, this is also used on other boards as kind of a convention.
According to the latest comment here:
opened 06:50PM - 06 Dec 16 UTC
closed 09:02AM - 15 May 19 UTC
Type: Feature Request
I am wondering when there will be support for the internal temperature sensor?
I'm hoping to do some internal diagnostics on my project, please let me know!
temp sensor feature is no longer supported
Is this related?
poesel
December 16, 2019, 11:22am
2
Espressif removed the internal temperature sensors from the newer ESP32s. The measurement was just too unreliable.
I don’t know how many chips Pycom has on stock but eventually they will have to drop support for it, too. So we can’t rely on it either.
Thias
December 16, 2019, 11:41am
3
Thanks. So, I’ll skip the reading in Terkin
Andreas
December 16, 2019, 4:48pm
4
