I would kindly ask you if you could assign me credentials for the protected data channel, which I would like to own. I would like to submit data using MQTT.
thanks for writing in. Sure, we will send you corresponding credentials soon, in order to enable you hosting your own data channel on swarm.hiveeyes.org.
apologies for the delay. I just created and sent out MQTT access credentials and an invitation to the Grafana instance. You should find an appropriate message in your PM inbox.
