Bad reading arrived
Sometimes things go wrong and you might find things like these in your database:
$ influx -database umwelt_airrohr -precision rfc3339
> SELECT bme_t, dht_t, p10, p25 FROM research_node_5_sensors ORDER BY time DESC LIMIT 3;
time bme_t dht_t p10 p25
2036-02-07T06:28:00Z 21.35 19.8 424.5 361.3
2019-01-18T04:54:00Z 20.61 19.2 413.8 316.9
2019-01-18T04:53:00Z 20.63 19.2 406.4 316.8
Identify reading
To delete this weird reading from the future at 2036-02-07T06:28:00Z, check again for the timestamp in unix epoch
2085978480000000000 21.35 19.8 424.5 361.3
1547787300000000000 20.61 19.2 410.1 317.6
1547787240000000000 20.61 19.2 413.8 316.9
Remove reading
and finally delete the erratic record
> DELETE FROM research_node_5_sensors WHERE time=2085978480000000000;
