Description
Microchip’s ENC28J60 is a 28-pin, 10BASE-T stand alone Ethernet Controller with on board MAC & PHY, 8 Kbytes of Buffer RAM and an SPI serial interface. With a small foot print package size the ENC28J60 minimizes complexity, board space and cost. Target applications include VoIP, Industrial Automation, Building Automation, Home Control, Security and Instrumentation.
Features
- ENC28J60 Ethernet controller in the world’s most compact header form
- LAN connector with build in transformer
- Two status LEDs on LAN connector
- SPI interface takes only few pins to add Ethernet interface to your microcontroller project
- 10 pin interface on 0.1" row pins header
- PCB: FR-4, 1.5 mm (0,062"), green soldermask, white silkscreen component print
- Dimensions: 30x24 mm (1.18 x 0.95")
- Space between the pin rows: 20 mm (0.8")
Links
ENC28J60-H (€13.95)
Ethernet Interface Board - ENC28J60 - BOB-00765 - SparkFun Electronics ($34.95)
ENC28J60 – Mikrocontroller.net
Tutorials
