Ready for your weighing needs..
Full control of the NAU7802, Comes with preloaded software.Demo coming soon..
Nice!
I mainly use the nau7802 break-out-board from adafruit with a QWIIC interface, that enables to use whatever MCU board is wanted (in my case a nRF9151 feather, a LTE-M/NB-IoT modem).
The adafruit board has for my usage mainly two downs:
I’m not sure, if your board is intended to run from battery and has something as a “power LED”. If so, let me recommend to use a “solder jumper” to easily disable it.
And if there is enough “space”, I would consider the solder pads for a second 5-wire plug, to add it, when two load-cells are used.
Nice. What library are you using? I have a similar setup, but the scale/library stops responding after several days and only sends back an error code.
OT: Same here! I reported this to Adafruit (I didn’t have the LED in mind at the time because only a graphic of the PCB had been published), and Lady Ada herself replied: Suggestions to the load cell connectors at the PCB preview · Issue #1 · adafruit/Adafruit_NAU7802 · GitHub . It was issue #1 on the Adafruit_NAU7802 GitHub page! But nothing has changed since then.
I opened a ticket in the forum (2024) about the power LED
and in the meantime, quite a lot are requesting that. We will see.
I planned a QWIIC NAU7802 + BQ25186 board … but I wasn’t able to spend time into it for now. We will see.
