Migrating from Node-RED / Blynk to Kotori, InfluxDB and Grafana
Dear Christophe,
I’ve put together some links to get you started. While not everything will match your use-case, it might get you some insights into the system and the variety of possibilities to acquire data from different kinds of sensor nodes using different protocols and telemetry scenarios.
The content within the last topic has been split up to make the translator work again.
We’ve just sent you an invite to this Grafana instance.
Sure, just go ahead and don’t hesitate to ask.
P.S.: In order to run the whole backend system on your own premises, you might want to have a look at the respective documentation of Kotori at https://getkotori.org/docs/setup/debian.html. We’ve tried hard to make it as easy as possible by providing appropriate software packages from our repository, even for Raspberry Pi and other SBC systems. Some people from our community have already been doing this successfully, see Kotori Setup auf Raspbian Buster – thanks again for writing about it, @techanic!
