Lossy audio compression codecs
Contrary to requirements around Lossless Audio Compression Codecs, compressing audio with losses is sometimes acceptable for the benefit of accompanying lower bitrates.
There’s plenty of research and a plethora of technologies and codec implementations; can we even enumerate them, starting with the invention/popularization of MP3, or even before?
Placeholder I.
TSAC Very Low Bitrate Audio Compression
Today, we’d like to present the TSAC codec published by Fabrice Bellard just recently in 2024.
TSAC: Very Low Bitrate Audio Compression
Please note because the reference implementation favors a GPU silicon for encoding today, it is currently not suitable for general purpose use. Please also note recent works of Fabrice Bellard are commercial software and no longer open source.
A GPU is necessary for fast operation. CPU only is also supported but slower.
Description
  • tsac relies on a modified model of the Descript Audio Codec prolonged for stereo and a Transformer mannequin to additionally improve the compression ratio. Both fashions are quantized to eight bits per parameter.
  • The Transformer mannequin is evaluated in a deterministic and reproducible means. Hence the outcome doesn’t rely on the precise GPU or CPU mannequin nor on the variety of configured threads. This key level ensures {that a} compressed file may be decompressed utilizing a completely different {hardware} or software program configuration.
References (press)
References (community)
Origins
