Excellent.
Thanks already!
Excellent.
Thanks already!
I have an issue when i try to install. An issue with dependencies
pi@raspberrypi:/etc/apt $ sudo apt-get install kotori influxdb grafana mosquitto mosquitto-clients
Lecture des listes de paquets⊠Fait
Construction de lâarbre des dĂ©pendances
Lecture des informations dâĂ©tat⊠Fait
Certains paquets ne peuvent ĂȘtre installĂ©s. Ceci peut signifier
que vous avez demandĂ© lâimpossible, ou bien, si vous utilisez
la distribution unstable, que certains paquets nâont pas encore
Ă©tĂ© créés ou ne sont pas sortis dâIncoming.
Lâinformation suivante devrait vous aider Ă rĂ©soudre la situation :
Les paquets suivants contiennent des dépendances non satisfaites :
mosquitto-clients : Dépend: libmosquitto1 (= 1.5.6-0mosquitto1) mais ne sera pas installé
E: Impossible de corriger les problĂšmes, des paquets dĂ©fectueux sont en mode « garder en lâĂ©tat ».
Thanks for reporting this problem. This is probably on us as we obviously forgot to add libmosquitto-1.5.6 from upstream [1] when populating the unified package repository [2].
After experiencing different issues with the Mosquitto daemon shippped with vanilla Debian, we decided to provide packages from upstream the other day.
We will fix this problem right away.
[1] Index of /debian/pool/main/m/mosquitto/
[2] Index of /hiveeyes/foss/debian/pool/foundation/m/mosquitto/
We just added the missing files to the package repository [1]. Would you try again after updating the package index using "apt update"?
Thanks already,
[1] Index of /hiveeyes/foss/debian/pool/foundation/m/mosquitto/
Dear @georges.gagliano,
Did adding this package to the repository resolve the installation problems on RaspberryPi machines?
With kind regards,
