»grafana-metadata-api«
We are coming from Developing the »grafana-metadata-api« here.
Goal
Conveniently access multiple JSON files through a single native Grafana datasource based on the Grafana Simple JSON Datasource plugin.
This can be used to implement lookup and concordance tables and consume them easily from within Grafana.
Implementation
The server-side component of the Grafana Metadata API is serving as a hackable datasource implementation. Being in its infancy, it just delivers static JSON files after applying some basic routing.
It is based on the Simple JSON Datasource plugin, a backend datasource that sends generic HTTP requests to a given URL.
The grafana-metadata-api handler has been implemented with Nginx/Lua, responding to requests from simple-json-datasource.
Setup
The software "grafana-metadata-api" has been installed and configured on the data acquisition host weather.hiveeyes.org by following the corresponding setup documentation.
The new data source "environmental-metadata" has been added to pull this into Grafana.
Type:   SimpleJson
URL:    https://weather.hiveeyes.org/metadata
Access: proxy
Screenshots
Adding a new data source
The data source has been added
Howto: Publish and consume your own JSON metadata file
This document outlines the process of publishing and consuming a JSON file as a Grafana datasource along the lines of a meaningful example.
Publish
Just drop more .json files into the "/var/lib/grafana-metadata-api" directory, like luftdaten-stations-grafana.json:
  {"value": 8119, "text": "Karlsbader Stra\u00dfe, B\u00fcchenbach, Bayern, DE"},
  {"value": 1234, "text": "Hauptstra\u00dfe, Wolfratshausen, Bayern, DE"}
Grafana will use the "text" property as a the template variable’s label and the "value" property as the raw value of the template variable.
Implement
Add another Grafana variable to your dashboard (see configure Grafana variable) based on a data source already configured.
Example
Add a variable named "location_id" backed by the file "luftdaten-stations-grafana.json" from the "environmental-metadata" data source.
Label:          Location
Type:           Query
Data source:    environmental-metadata
Query:          luftdaten-stations-grafana.json
Refresh:        On Dashboard Load
Sort:           Alphabetical (asc)
Multi-value:    yes
Screenshot
Use
After implementing the variable in this way, it will be displayed as a select component at the top of the dashboard, as usual:
However, when using the select widget, it will propagate the numerical identifier values into the variable "location_id", not their textual representations.
Wow, that is something!
