Getting started with Flux
influxdb
#1
About Flux
Introduction to Flux
Flux (formerly IFQL) is the new InfluxDB query language and engine we already talked about at The history and future of InfluxDB and Temperatursummen in der Imkerei.
Flux is a lightweight scripting language for querying databases (like InfluxDB) and working with data. It’s part of InfluxDB 1.7 and 2.0, but can be run independently of those.
See also: Flux Specification.
Flux vs. InfluxQL
InfluxQL is InfluxData’s SQL-like query language for interacting with data in InfluxDB. Flux is an alternative to InfluxQL and other SQL-like query languages for querying and analyzing data. It uses functional language patterns making it incredibly powerful, flexible, and able to overcome many of the limitations of InfluxQL. This article outlines many of the tasks possible with Flux but not InfluxQL and provides information about Flux and InfluxQL parity.
Flux vs InfluxQL | InfluxData Documentation
Remark: Please follow this link to get an at-a-glance like introduction to Flux’s features by looking at things which haven’t been possible with InfluxQL.
Rationale for Flux
A Note on IFQL
The combination of schema-on-write, automatic indexing of tagsets , and SQL-like syntax produce a system that allows newcomers to be productive quickly, that feels familiar, and requires minimal setup to get started.
However, the pre-allocation of narrowly scoped iterators means high-cardinality queries, and queries that produce a very large number of groups are expensive to plan. The iterator structures can consume, worst case, GBs of RAM. Secondly, the iterator allocation during planning and other implementation details make multi-query resource management difficult. Finally, while SQL-like syntax is a good fit for simple queries, it becomes cumbersome for more sophisticated analytics. Time series queries are often sets of functions applied to groupings of filtered streams. Expressing these queries using select-project-join logic with advanced SQL partition and over clauses requires an experienced SQL programmer and is no longer beginner- friendly.
We recently announced a prototype query language, IFQL, to explore solutions to these problems: cheaper planning, better resource management, and easier expression of complex queries.
Querying Data Optimally | InfluxDB Internals 101 [Part Two] (Nov, 2017)
Documentation
Articles
2017
2018
The Design of IFQL, the New Influx Functional Query Language
by Paul Dix, the founder of InfluxData and principal architect of Flux (formerly IFQL):
The new InfluxDB query language is functional in nature. Conceptually it looks like D3 or jQuery. Functions are chained off each other. This gives greater flexibility for what the language can do and opens up new possibilities for UI builders. This talk will cover the details of the language and user interface ideas that can pair up nicely with it. We’ll look at query examples that perform math on metrics, interpolation, and similarity measures.
Important notes about Flux
Key concepts » Buckets
Flux introduces “buckets”, a new data storage concept for InfluxDB. A bucket is a named location where data is stored that has a retention policy. It’s similar to an InfluxDB v1.x “database,” but is a combination of both a database and a retention policy.
Get started with Flux » Key concepts » Buckets
Specify a time range
Flux requires a time range when querying time series data. “Unbounded” queries are very resource-intensive and as a protective measure, Flux will not query the database without a specified range.
Query InfluxDB with Flux » Specify a time range
Using Flux from Grafana
Upgrade to InfluxDB 1.7.2 and Grafana 5.4.2
#2
Test drive
Despite it will be arriving soon in mainline as there is a schedule for the InfluxDB Master Branch to Switch to 2.0 on Jan 11 | InfluxData (thanks @weef), we are all eager to check it out.
As the Testdrive of InfluxData OSS 2.0 failed to get us Flux into Grafana through Flux (InfluxDB) [BETA] plugin for Grafana | Grafana Labs, we are now trying to just Upgrade to InfluxDB 1.7.2.
#3
Flux from the commandline
InfluxDB 1.7.2 supports Flux out-of-the-box already, just add "flux-enabled = true" to its configuration file.
See also Different ways to execute Flux queries » Influx CLI in “Flux mode” ff.
Invoke the REPL shell
influx -precision rfc3339 -type flux
Connected to http://localhost:8086 version 1.7.2
InfluxDB shell version: 1.7.2
Enter a Flux query
Execute Flux query
> from(bucket:"hiveeyes_open_hive_clemens") |> range(start: -1h) |> last()
Result
Result: _result
Table: keys: [_start, _stop, _field, _measurement]
                   _start:time                      _stop:time           _field:string     _measurement:string                      _time:time                  _value:float
2019-01-06T20:13:58.532965601Z  2019-01-06T21:13:58.532965601Z     Aussen-Feuchtigkeit       default_2_sensors  2019-01-06T21:06:40.000000000Z                            71
2019-01-06T20:13:58.532965601Z  2019-01-06T21:13:58.532965601Z       Aussen-Temperatur       default_2_sensors  2019-01-06T21:06:40.000000000Z                           5.9
2019-01-06T20:13:58.532965601Z  2019-01-06T21:13:58.532965601Z                 Gewicht       default_2_sensors  2019-01-06T21:06:40.000000000Z                         8.188
2019-01-06T20:13:58.532965601Z  2019-01-06T21:13:58.532965601Z                Spannung       default_2_sensors  2019-01-06T21:06:40.000000000Z                          3.67
#4
Flux via InfluxDB HTTP API
See also Different ways to execute Flux queries » InfluxDB API.
Request
echo 'from(bucket:"hiveeyes_open_hive_clemens") |> range(start: -1h) |> last()' | \
    http localhost:8086/api/v2/query Content-Type:application/vnd.flux
Response
Headers
HTTP/1.1 200 OK
Content-Encoding: gzip
Content-Type: text/csv; charset=utf-8
Date: Sun, 06 Jan 2019 22:48:01 GMT
Request-Id: 1eee2579-1205-11e9-8b65-00163e08ddd3
Transfer-Encoding: chunked
X-Influxdb-Build: OSS
X-Influxdb-Version: 1.7.2
X-Request-Id: 1eee2579-1205-11e9-8b65-00163e08ddd3
Body
#datatype,string,long,dateTime:RFC3339,dateTime:RFC3339,dateTime:RFC3339,double,string,string
#group,false,false,true,true,false,false,true,true
#default,_result,,,,,,,
,result,table,_start,_stop,_time,_value,_field,_measurement
,,0,2019-01-06T21:48:01.457170176Z,2019-01-06T22:48:01.457170176Z,2019-01-06T22:46:40Z,73.3,Aussen-Feuchtigkeit,default_2_sensors
,,1,2019-01-06T21:48:01.457170176Z,2019-01-06T22:48:01.457170176Z,2019-01-06T22:46:40Z,5.3,Aussen-Temperatur,default_2_sensors
,,2,2019-01-06T21:48:01.457170176Z,2019-01-06T22:48:01.457170176Z,2019-01-06T22:46:40Z,8.188,Gewicht,default_2_sensors
,,3,2019-01-06T21:48:01.457170176Z,2019-01-06T22:48:01.457170176Z,2019-01-06T22:46:40Z,3.67,Spannung,default_2_sensors
#5
Flux via Grafana
When intending to use Grafana with Flux, we ask you to follow up reading …
#6
Flux by example
When diving into Flux, please read the following sections carefully. They will guide you from basic examples to semi advanced ones.
Prepare data
To prepare some data points, just add them like
# Define ingest address for data channel.
target=https://weather.hiveeyes.org/api/umwelt/testdrive/flux/test-01/data
# Submit some measurement points.
echo '{"temperature": 42.42, "humidity": 84.84, "rssi": 50.50}' | http $target
sleep 1.5
echo '{"temperature": 44.42, "humidity": 80.84, "rssi": 55.55}' | http $target
sleep 1.5
echo '{"temperature": 46.42, "humidity": 70.78, "rssi": 60.80}' | http $target
sleep 1.5
echo '{"temperature": 53.42, "humidity": 50.50, "rssi": 57.30}' | http $target
sleep 1.5
echo '{"temperature": 51.39, "humidity": 48.00, "rssi": 53.53}' | http $target
sleep 1.5
echo '{"temperature": 36.36, "humidity": 75.75, "rssi": 64.64}' | http $target
[o] TODO: Add a more sensible example dataset. Does someone have an idea about a 3-5 column, reasonably-sized CSV dataset we could use here?
#7
Basic queries
These examples will show the legacy SQL-like InfluxQL and the new Flux query expressions and their results side by side. Please also have a look at the official documentation about how to Query InfluxDB with Flux | InfluxData Documentation.
As having a time-based filter component as minimum expression constraint is obligatory with Flux …
… we will use a simple filter like "now()-1h" for restricting the time range.
Expressions
InfluxQL
# Define InfluxQL expression.
expression='SELECT * FROM flux_test_01_sensors WHERE time > now()-12h;'
# Submit expression to database.
echo $expression | influx -precision rfc3339 -type influxql -database "umwelt_testdrive"
Flux
# Define Flux expression.
expression='
from(bucket:"umwelt_testdrive")
  |> range(start: -12h)
  |> filter(fn: (r) => r._measurement == "flux_test_01_sensors")
echo $expression | influx -precision rfc3339 -type flux
Results
InfluxQL
Querying by InfluxQL produces columnar data output (one column per field) by default.
time                           humidity rssi  temperature
2019-01-08T00:27:20.975467141Z 84.84    50    42.42
2019-01-08T00:27:54.828403444Z 80.84    55    44.42
2019-01-08T00:28:15.657730499Z 70       60.8  46.42
2019-01-08T00:28:33.315969281Z 50       57.3  53.42
2019-01-08T00:28:46.551228316Z 48       53.53 51.39
2019-01-08T00:29:06.491641575Z 75.75    64.64 36.36
Flux
Querying by Flux will yield timeseries-style results. More precisely, all results will get grouped into one timeseries table per field. As our schema has three fields "temperature", "humidity" and "rssi", we will receive three timeseries tables, respectively containing all data points for each field at a time.
Result: _result
2019-01-07T23:42:33.662834823Z  2019-01-08T00:42:33.662834823Z                humidity    flux_test_01_sensors  2019-01-08T00:27:20.975467141Z                         84.84
2019-01-07T23:42:33.662834823Z  2019-01-08T00:42:33.662834823Z                humidity    flux_test_01_sensors  2019-01-08T00:27:54.828403444Z                         80.84
2019-01-07T23:42:33.662834823Z  2019-01-08T00:42:33.662834823Z                humidity    flux_test_01_sensors  2019-01-08T00:28:15.657730499Z                            70
2019-01-07T23:42:33.662834823Z  2019-01-08T00:42:33.662834823Z                humidity    flux_test_01_sensors  2019-01-08T00:28:33.315969281Z                            50
2019-01-07T23:42:33.662834823Z  2019-01-08T00:42:33.662834823Z                humidity    flux_test_01_sensors  2019-01-08T00:28:46.551228316Z                            48
2019-01-07T23:42:33.662834823Z  2019-01-08T00:42:33.662834823Z                humidity    flux_test_01_sensors  2019-01-08T00:29:06.491641575Z                         75.75
2019-01-07T23:42:33.662834823Z  2019-01-08T00:42:33.662834823Z                    rssi    flux_test_01_sensors  2019-01-08T00:27:20.975467141Z                            50
2019-01-07T23:42:33.662834823Z  2019-01-08T00:42:33.662834823Z                    rssi    flux_test_01_sensors  2019-01-08T00:27:54.828403444Z                            55
2019-01-07T23:42:33.662834823Z  2019-01-08T00:42:33.662834823Z                    rssi    flux_test_01_sensors  2019-01-08T00:28:15.657730499Z                          60.8
2019-01-07T23:42:33.662834823Z  2019-01-08T00:42:33.662834823Z                    rssi    flux_test_01_sensors  2019-01-08T00:28:33.315969281Z                          57.3
2019-01-07T23:42:33.662834823Z  2019-01-08T00:42:33.662834823Z                    rssi    flux_test_01_sensors  2019-01-08T00:28:46.551228316Z                         53.53
2019-01-07T23:42:33.662834823Z  2019-01-08T00:42:33.662834823Z                    rssi    flux_test_01_sensors  2019-01-08T00:29:06.491641575Z                         64.64
2019-01-07T23:42:33.662834823Z  2019-01-08T00:42:33.662834823Z             temperature    flux_test_01_sensors  2019-01-08T00:27:20.975467141Z                         42.42
2019-01-07T23:42:33.662834823Z  2019-01-08T00:42:33.662834823Z             temperature    flux_test_01_sensors  2019-01-08T00:27:54.828403444Z                         44.42
2019-01-07T23:42:33.662834823Z  2019-01-08T00:42:33.662834823Z             temperature    flux_test_01_sensors  2019-01-08T00:28:15.657730499Z                         46.42
2019-01-07T23:42:33.662834823Z  2019-01-08T00:42:33.662834823Z             temperature    flux_test_01_sensors  2019-01-08T00:28:33.315969281Z                         53.42
2019-01-07T23:42:33.662834823Z  2019-01-08T00:42:33.662834823Z             temperature    flux_test_01_sensors  2019-01-08T00:28:46.551228316Z                         51.39
2019-01-07T23:42:33.662834823Z  2019-01-08T00:42:33.662834823Z             temperature    flux_test_01_sensors  2019-01-08T00:29:06.491641575Z                         36.36
#8
Now, let’s switch to the HTTP interface like Querying our InfluxDB databases interactively. In order to do so, you will have to authenticate appropriately:
http --session=hiveeyes https://weather.hiveeyes.org/influx/ --auth <username>:<password>
#9
Projection
How to use Projection (relational algebra) - Wikipedia with InfluxDB/Flux. You can either
Keep specific columns
See also keep() function | InfluxData Documentation.
expression='
  |> range(start: -12h)
  |> filter(fn: (r) =>
  |> keep(columns: ["_time", "_field", "_value"])
echo $expression | http --session=hiveeyes https://weather.hiveeyes.org/influx/api/v2/query Content-Type:application/vnd.flux
Drop specific columns
See also drop() function | InfluxData Documentation.
expression='
  |> range(start: -12h)
  |> filter(fn: (r) =>
  |> drop(columns: ["_start", "_stop", "_measurement"])
#10
Cardinality
How to compute the Cardinality - Wikipedia of datasets with InfluxDB. In other words, this is about finding out how many records are stored in your database table.
InfluxQL
expression='
SELECT count(*)
http --session=hiveeyes https://weather.hiveeyes.org/influx/query \
    db==umwelt_testdrive \
    q=="$expression"
Flux
expression='
  |> range(start: -12h)
  |> filter(fn: (r) =>
  |> count() |> keep(columns: ["_value"])
