… dann Programmablauf anhalten per CTRL+C und Justierungsroutine starten per
>>> datalogger.scale_wizard()
Synopsis
Weight scale adjustment
Step 1: Select sensor device
0: scale-1
Type index: 0
15.5881 [terkin.driver.hx711_sensor ] INFO : Powering up HX711
15.6084 [terkin.lib.hx711 ] INFO : HX711 power up
15.6263 [terkin.lib.hx711 ] INFO : HX711 power up
15.6439 [terkin.lib.hx711 ] INFO : Initialization started
15.6636 [terkin.lib.hx711 ] INFO : Initialization succeeded
Step 2: Unloaded scale
Please remove all weight from the scale.
When done, press any key to continue.
Step 3: Loaded scale
Please load the scale with a known weight.
When done, input the kilogram value.
Weight (kg): 1
Step 4: Configure settings
Please use the computed values for configuring your settings.py
offset: 74554.0
scale: -17970.5
Die ermittelten Werte dann in die settings.py eintragen.
