Sources: BeagleBone Enhanced – SanCloud, SanCloud:BeagleBoneEnhanced - eLinux.org
The BeagleBone Enhanced embedded computer is a member of the BeagleBoard family. It is a lower-cost, high-expansion focused BeagleBoard using a low cost Sitara XAM3359AZCZ100 Cortex A8 ARM processor from Texas Instruments. It is similar to the Beaglebone, but with some features removed and some features added.
The system still has a blistering 1GHz processor and like the BeagleBone Black, two 46-pin headers, micro HDMI for audio/video output, USB ports, Ethernet and other I/O features. The wiki page SanCloud:BeagleBoneEnhanced - eLinux.org outlines more details about the differences between the BeagleBone and BeagleBone Enhanced.
There are 3 variants available.
BeagleBone Enhanced WiFi 512
- 3 additional USB ports
- Gigabit Ethernet
- Optional SPI flash for bootloader
BeagleBone Enhanced WiFi – V1G
- 1G Byte onboard DDR3 RAM
- Gigabit Ethernet
- 6 axis MEMS accelerometer/gyro
- Barometer and temperature sensor
BeagleBone Enhanced Industrial
- spec’ed for industrial temperature range
- no default wifi (because of extended temp range)
- same other features as the V1G above
Support
For support please refer to the elinux.org page SanCloud - eLinux.org.
