Description:
ESP8266 and ESP32 modules are widely used in home automation, measurement, monitoring, control and other typical IoT applications. The AZ-Touch wall-mounted housing set is a touch screen housing set that also uses an ESP8266 and ESP32 platform as a base and can therefore be quickly and easily connected to NodeMCU and AZDelivery D1 mini boards.
Depending on your project and software, you can mount the housing set vertically or horizontally directly on the wall.
The AZ-Touch set comes in a beautiful wall-mountable housing together with a 2.8-inch resistive touchscreen and allows you to permanently mount your AZ-Touch project in your living room, corridor or other locations.
Unlike the previous model, this version is already pre-loaded!
Product:
2.8 inch (7.12 cm) TFT screen with 320x240 pixel resolution
SPI display controller ILI9341
Resistive Touch with SPI Touch Controller XPT2046
Integrated 5V/1.4A Voltage Regulator (9-35V DC)
• Integrated prototyping area
6-PIN removable terminal block for power supply in prototyping area 6
• Slots for AZDelivery D1 Mini and NodeMCU ESP32 (ESP32-Dev-Kit C)
• Vented lid for letting through airflow
