The GitHub - hiveeyes/arduino: Arduino-compatible MCU code for sensor and telemetry nodes repository does not contain any examplars with LoRa/LoRaWAN telemetry, as mentioned by @lbussy at Asking for guidance to find the right hardware/software kit for a connected hive in a rural setting - #21 by lbussy. This post aims to fill this gap.
Overview
Both applicances/firmwares in this section are based on the HTCC-AB01: Heltec CubeCell Dev-Board, using a Cortex M0+. Both run their telemetry messaging via LoRaWAN to TTN. Kudos to both authors for sharing their excellent work.
Comparison
Autonome Zelle #3
Autonome Zelle #3: Bodentemperaturen mit CubeCell, DS18B20, Solar & LoRa has been conceived by @wtf.
- Sensors: DS18B20.
- Telemetry: CayenneLPP over LoRaWAN.
- Status: Running in production.
- Documentation: Extensive. Includes hardware design, BOM, pictures.
- Repository: autonome-zelle / az3-cubecell-boden · GitLab
- Firmware: az3-cubecell-boden/main.ino
Hivescale_HTTC-AB01_Lorawan
Hivescale_HTTC-AB01_Lorawan has been conceived by @MKO, see also 8266 - homie battery powered OR Bienenwaage 2.0 NodeMCU? - #6 by MKO.
- Sensors: HX711, NAU7802, BME280.
- Telemetry: Custom binary payload over LoRaWAN.
- Status: Under construction.
- Documentation: No.
- Repository: GitHub - MKO1640/Hivescale_HTTC-AB01_Lorawan
- Firmware: Hivescale_AB01.ino
Outlook
It would be sweet to mix both firmwares together to get the best of both worlds, specifically suitable for implementing a connected hive with support for NAU7802 and LoRaWAN, CayenneLPP serialization and PlatformIO.
- Sensors: NAU7802, BME280, DS18B20.
- Sandbox: PlatformIO configuration file.
