We finally managed to import historical data from @clemens (Open Hive) and some of his peers. Thanks and cheers!
Results
Some historical measurement data collected over the past two years from different apiaries:
- https://swarm.hiveeyes.org/grafana/dashboard/db/open-hive-clemens
- https://swarm.hiveeyes.org/grafana/dashboard/db/open-hive-frank
- https://swarm.hiveeyes.org/grafana/dashboard/db/open-hive-jorg
- https://swarm.hiveeyes.org/grafana/dashboard/db/open-hive-sepp
Clemens also operates a test stand on his balcony using the Open Hive WiFi Solar / Adafruit HUZZAH to collect long term measurements of a load cell in order to find out about creep and drift behavior as well as temperature effects on the measurements:
As the server receiving measurement data from the Open Hive GSM and WiFi sensor nodes in CSV format is still running PHP4, we used Terkin for PHP4 as a library to forward data to the Hiveeyes platform using HTTP. This is similar to @mois’ setup, see also:
